Re: Carter 500's, can this mess be fixed & if so worth it?
[Re: ScottSmith_Harms]
#1437034
05/17/13 05:49 AM
05/17/13 05:49 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Looking good, those should cleaned up great! ........Look what I'm facing this evening
With glass bead I was expecting a different finish, different grit perhaps?
Wow, those poor 409 carbs look like they spent time in a lake! What a mess.
#1437035
05/17/13 10:20 AM
05/17/13 10:20 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
And the owner "Helped" me get the throttle shafts free......By bending the blades in half with a screw driver.......
We both know those will buff out ! ![](/ubbthreads/images/graemlins/biggrin.gif)
#1437037
05/17/13 11:15 AM
05/17/13 11:15 AM
62maxwgn
Blair County,PA
Yes glass beading (or other media blasting) can leave a high degree of surface texture/appearance variability depending on the type/size/pressure of the media. I avoid blasting in my process if at all possible but some really rough examples (i.e. these 409 carbs) will require it. In this case its only one of several steps used to revive the factory look (vibratory finisher, sonic cleaner, tumbler, etc.).
You forgot one item !! ![](/ubbthreads/images/graemlins/biggrin.gif)
Also,check your email
[Re: gdonovan]
#1437040
05/17/13 01:38 PM
05/17/13 01:38 PM
62maxwgn
Blair County,PA
No luck on that one jet yet, would not budge this morning even with an easy out in it. When I get home tonight, I might try heating the casting and placing something cold on the jet and see if it pops loose.
Really should have left it alone ! ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 62maxwgn]
#1437042
05/17/13 07:46 PM
05/17/13 07:46 PM
gdonovan
Oakdale CT
Got it out but it put up a hell of a fight!
[Re: gdonovan]
#1437045
07/31/13 04:55 AM
07/31/13 04:55 AM
gdonovan
Oakdale CT
Units are 4758S and 4761S 500's and worked fabulous on my 440.
Question- Does anyone know what the stock jetting is for these two carburetors? I looked everywhere this morning but could find no reference.
They have a lean spot just off idle (not transition but steady throttle) and I want to return them to a baseline before making changes but don't know what the baseline jetting is.
[Re: Skeptic]
#1437047
07/31/13 05:33 PM
07/31/13 05:33 PM
gdonovan
Oakdale CT
Here is what Edelbrock has listed for the 500cfm AVS knockoff, with single and dual quad listings. That's the way I set my 4966 carbs up with, the engine doesn't go on the dyno for a few weeks. We'll see how close they are then.
Thanks! I looked at the AFB listings since thats what I'm running, AVS secondaries are very different than the AFB.
[Re: Skeptic]
#1437049
07/31/13 11:06 PM
07/31/13 11:06 PM
gdonovan
Oakdale CT
Edelbrock has the primary and secondary jets mixed.
Larger jets go on the primary side.
[Re: gdonovan]
#1437050
08/01/13 09:37 AM
08/01/13 09:37 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
#1803/#1804 are calibrated for dual-quad applications and factory equipped with: Metering Jets -Primary .086, Secondary .077 ; Metering Rods - .065 x .057; #1804:Metering Jets -Primary .086, Secondary .077 ; Metering Rods - .065 x .052; Step-Up Spring - orange (5" Hg).
[Re: Skeptic]
#1437052
08/01/13 10:01 AM
08/01/13 10:01 AM
gdonovan
Oakdale CT
You listed the wrong carb, look up a 500 CFM AFB (performer series).
"Comes with: Metering Jets - Primary .086, Secondary .095; Metering Rods - .065 x .052; Step-Up Spring - orange (5" Hg)"
This is incorrect, I spent hours last night chasing my tail due to it.
[Re: Skeptic]
#1437053
08/01/13 10:07 AM
08/01/13 10:07 AM
gdonovan
Oakdale CT
Those carbs look great, what did you use to refinish them?
Glass bead from Tractor Supply, new screws from True Value Hardware, kits and floats from Ebay and gold paint from AC Moore.
