4 speed swap #1436021
05/13/13 09:35 PM
05/13/13 09:35 PM
Gilroy,CA.
mopardude318 Offline OP
Gilroy,CA.
Well, the 318/904 combo works pretty damn good... 3000 stall, shifts hard, lays rubber nicely, very responsive. Just time to go manual, I think I'd enjoy it even more. I always dream about rowin' my own gears!
So I rebuilt an A-body 4 speed, got a Hurst Comp plus shifter, new shift rods and clutch linkage from Brewers, bought this Ram Clutches 3 finger clutch and billet steel flywheel a while ago, have to paint and install my pedal assembly.
Got the rest of the parts I needed at the Spring Fling this weekend which persuaded me to go ahead with the swap...After hearing a guys 69 Dart with a mechanical cam and 4 speed, made me say, "yep, I want a 4 speed!"
I have TTI headers, so I bought their Z-bar to go with it, since I didn't have one anyway.
Any hints, tips, tricks, thoughts are welcome as I've never done this before. :happy8:
I'll be posting updates of the progress. Not gonna start the swap until after June 2nd, I wanna take it to Mopar Rally first. I don't think I could finish before then. lol
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: 4 speed swap [Re: mopardude318] #1436022
05/13/13 11:08 PM
05/13/13 11:08 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Looking good so far I'm using that same disc this year with my new street conversion.I am pulling the race 5-speed out and putting a nice 18 spline street 4-speed in the Savoy with a soft and easy clutch.No more severe shudder from the six puck bronze disc just backing into a spot at the local cruise-in.Still not sure if I will take the spool out of the rear yet
Gus
64 Plymouth Savoy
Dana 60
Re: 4 speed swap [Re: fourgearsavoy] #1436023
05/17/13 12:18 AM
05/17/13 12:18 AM
Gilroy,CA.
Gilroy,CA.
Gus
Thank you. That 18 spline will be a nice unit for sure!
By the way, any one know where this spring clips to? I think I have it in the right spot on the clutch fork, there is a notch for it, don't see where the other side would go.
Re: 4 speed swap [Re: mopardude318] #1436024
05/17/13 08:40 AM
05/17/13 08:40 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
I replied to your redundant post on FABO.
Re: 4 speed swap [Re: Pntastar69] #1436025
05/17/13 12:20 PM
05/17/13 12:20 PM
Gilroy,CA.
Gilroy,CA.
Thank you!!!
I figured it out shortly after messin with it for a while. LOL
Re: 4 speed swap [Re: mopardude318] #1436026
05/18/13 02:34 PM
05/18/13 02:34 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Straight forward swap,jump in and it just makes sense.
who is that guy?
Re: 4 speed swap [Re: mopardude318] #1436027
05/18/13 03:52 PM
05/18/13 03:52 PM
I didn't see the new transmission hump? I'm going to go through the same thing, 4 speed hump, on a 1967 Dodge slant six car I'm converting to a BB with a stock type four speed Not to hijack this thread but who makes a decent 4 speed floor hump now?
Re: 4 speed swap [Re: Cab_Burge] #1436028
05/19/13 02:45 AM
05/19/13 02:45 AM
Gilroy,CA.
Gilroy,CA.
AutoMetalDirect makes a nice one. thats what I have shown in my photos.
Re: 4 speed swap [Re: mopardude318] #1436029
05/19/13 02:47 AM
05/19/13 02:47 AM
Gilroy,CA.
Gilroy,CA.
Some parts arrived today, so I assembled the pedals. Got em all painted.
Here's the roller bearing/bushing kit:
The HD spring dwarfs the standard over center spring!
Pressing the roller bearings into the pedal shaft:
Gettin lubed up:
Thought I would never get the spring on, thanks to Ranidart70, she gave me an idea!
all done
Re: 4 speed swap [Re: fourgearsavoy] #1436030
05/19/13 03:17 AM
05/19/13 03:17 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Hope that you have strong legs. That RAM clutch I see is a firm one. I tried driving another Duster that had that one. It wasn't easy. It never slipped though!
Re: 4 speed swap [Re: Jjs72D] #1436031
05/19/13 03:46 AM
05/19/13 03:46 AM
Gilroy,CA.
Gilroy,CA.
well, i have it and im committed. LOL I guess time will tell here shortly. I hope it aint too bad!
Re: 4 speed swap [Re: Jjs72D] #1436032
05/19/13 11:00 AM
05/19/13 11:00 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Our Dart has a RAM clutch and I agree, you need a strong left leg to drive it. But I drove it to Woodward and back (2 hours each way) in heavy traffic last year, so if I can do it...
The only thing I can think to add is the carpet. You may get lucky like we did and manage to stretch the old carpet over the hump. Otherwise you may need a new one. Good luck!
Re: 4 speed swap [Re: mopardude318] #1436033
05/19/13 02:23 PM
05/19/13 02:23 PM
Oops, I didn't see it at first Thanks for sharing
Re: 4 speed swap [Re: mopardude318] #1436034
05/20/13 12:13 AM
05/20/13 12:13 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
Have you checked your crankshaft to see if it's drilled for the pilot bushing? You'll also want to make sure it's drilled to the correct size if it is drilled, as they drilled an unfinished pilot hole in some of the automatic cranks but didn't do the final finishing for the hole since it was going into an automatic - it's almost the right size, but just a little too small for the bushing to fit. I've heard there's an undersized OD pilot bushing that can be used in those smaller unfinished holes (I believe it was NAPA that had them), or you can use a later roller bearing in place of the bushing.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: 4 speed swap [Re: Evil Monkey] #1436035
05/21/13 05:41 AM
05/21/13 05:41 AM
Gilroy,CA.
Gilroy,CA.
Well I decided to tackle it today, I pulled the engine and trans out, I wanted to see if my crankshaft was drilled, because I had no idea..
I forgot I needed a pilot bearing, so I went to Orielly's and they had one in stock.
Surprisingly my 318's cast crankshaft was drilled all the way for the input shaft...
This tapped right in, and bolted it all together. It fit fine...
More to come.
Re: 4 speed swap [Re: mopardude318] #1436036
05/21/13 12:50 PM
05/21/13 12:50 PM
dogdays Offline
dogdays  Offline
Dude!
I'm glad to see you strumbled onto the "better idea" pilot bearing. Makes it easy, doesn't it?
Also, thank you for shooting focused, well-lit pictures. It is one of my hopes that with digital cameras more people will take the time and the number of pictures needed to have decent pix. It seems as if many don't even look at the pictures before posting them.
R.
Re: 4 speed swap [Re: dogdays] #1436037
05/22/13 06:44 AM
05/22/13 06:44 AM
Gilroy,CA.
Gilroy,CA.
Today I cut out my floor for the tunnel, installed the engine and trans for mock up. The floor tunnel fits nicely. I pulled the plug in the inner fender, installed the ball stud and test fitted the Z-bar. Lines up good.
Tomorrow I will install the pedals, take the engine/trans back out, install the clutch and flywheel, and mess with the clutch linkage.
Re: 4 speed swap [Re: mopardude318] #1436038
05/27/13 05:26 PM
05/27/13 05:26 PM
Gilroy,CA.
Gilroy,CA.
Thought I should paint the bell housing. LOL
Got the pedals installed. For some odd reason, they were a PITA to get in! Removed the steering column, and everything else in the way.
Noticed there were 2 different kinds of clutch fork adjusting rod hardware. I think I like the top unit better, sits in the recess of the clutch fork nicely.
Re: 4 speed swap [Re: mopardude318] #1436039
05/27/13 05:27 PM
05/27/13 05:27 PM
Gilroy,CA.
Gilroy,CA.
Well, it's in and done, as far as the installation goes. I changed out the slip yoke and installed new solid U-joints.
With the clutch engaged, I have about a 1/16" to an 1/8" from the clutch disc to the flywheel, about about an 1/8" to 3/16" from the throwout bearing to the 3 clutch fingers when the clutch isn't engaged.
This pic is probably worthless.
The clutch linkage and Z-bar all work together very nicely. Not too harsh of a pedal feel at all. The TTI Z-bar clears the TTI headers, no mods had to be made, it all went together.
Now I just have to test it! I gotta finish up a few things and I'll let yall know how everything works.
Re: 4 speed swap [Re: mopardude318] #1436040
05/27/13 09:48 PM
05/27/13 09:48 PM
You may need to adjust the clutch linkage so the disc starts to disengage with the pedal way up high on the travel, maybe not Try it first, I always had to make the adjustments so there was very little clucth pedal travel to make the throwout bearing hit the fingers on the preesure plate to get them to shift cleanly. McLeod use to recommend .060 disc to flywheel or pressue plate clearances on thier race clutches with no marcel in the disc, you will need at least that with a street disc I use to shoot for .030 to .090 clearances bewteen the throwout bearing to the clutch fingers with the pedal all the way out, it depended on how thick the disc was, new or used
