727 identification #1435320
05/12/13 07:20 PM
05/12/13 07:20 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Is counting the splines (19, 23 or 24 spline) the only way to ID a 727? Is there another way to tell what year the trans is and if its a lock up or non?
Laine
NRCA Member
Re: 727 identification [Re: Lmopar69] #1435321
05/12/13 07:26 PM
05/12/13 07:26 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Oh yeah, small block is what I'm dealing with. If memory serves I was told it came out of a van...mi think a 78. So it SHOULD be a non lock up. I'll be rebuilding it in about 2 weeks to put behind a stout 360 in my challenger.
Any input on which rebuild kit and converter is appreciated too. Gonna be 99% street driven with 4:10s in the rear.
Laine.
Re: 727 identification [Re: Lmopar69] #1435322
05/13/13 12:18 AM
05/13/13 12:18 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Drivers side under the shift linkage at the pan rail there is a machined flat with numbers stamped on it .
Re: 727 identification [Re: JohnRR] #1435323
05/13/13 12:26 AM
05/13/13 12:26 AM
scratchnfotraction Offline
lock up will have a smooth tip about 1.5" on the input shaft for the lock up coverter clutch.
a non lock up will have splines all the way to end of input shaft.
check pan rail # to see what yr it is,anything could have been put together over the yrs.
