Steering issues with shock change.
#1435239
05/12/13 04:50 PM
05/12/13 04:50 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Last week I installed new Calvert Racing front shocks on the D-50.I just had stock shocks on it before.Now when I make a pass the truck wants to go to the left a little and I have to sorta fight it a bit while I am going down the track.A guy told me that it looked strange while going down the track. The left front is way up in the air and the right rear is alot lower than the left rear.It has Caltract bars and 9 way adjustable shocks on the rear.The bars have no preload on them. Anybody have any ideas how to fix the issue without putting the stock shocks back on. Thanks....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Steering issues with shock change.
[Re: D-50]
#1435240
05/12/13 05:15 PM
05/12/13 05:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
See if the LF shock is seized for some reason (see if the LF will bounce up and down... check the other side while your at it)
[Re: D-50]
#1435244
05/12/13 09:23 PM
05/12/13 09:23 PM
MR_P_BODY
I went out and pushed up and down on the front and both sides seemed the same. It is very loose on the front.
And you said all you did was change the front shocks and now the truck is acting all weird .. am I correct on this... sounds like its a shock issue to me but it COULD be a bad shock like it has no oil in it... just a guess
[Re: MR_P_BODY]
#1435246
05/13/13 08:57 PM
05/13/13 08:57 PM
D-50
North, Alabama
Mr. P Body I am going to swap the front shocks around and see if that makes a difference.If one is bad I think it should act different than it does now good or bad.
[Re: D-50]
#1435247
05/13/13 09:04 PM
05/13/13 09:04 PM
MR_P_BODY
This is true.. if its a shock issue it should follow it
[Re: DblOJoe]
#1435248
05/14/13 08:48 AM
05/14/13 08:48 AM
Posts: 2,937 A shed in England
Tig
A shed in England
fwiw My car didn't like the Calvert shocks either. It wondered around to much for my liking.
Same problem here, I sold them to a friend after I removed them, he was well aware of the issues and I told him to try them first. He liked them and they worked great on his car. Similar weight and HP, longer wheelbase (B v's E). Go figure
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#1435249
05/17/13 12:07 AM
05/17/13 12:07 AM
D-50
North, Alabama
I put some preload on the passenger side Caltract bar and the truck drives alot better going down the track. It had about 1/8 gap before.I guess I can keep the Calvert front shocks on.More tuning next week.
