Re: Vibration problem...need help!
[Re: bigblk66_coronet]
#1434765
05/12/13 01:40 PM
05/12/13 01:40 PM
RapidRobert
X2, put it up on 4 stands in park/idling & see what you see
#1434767
05/12/13 05:00 PM
05/12/13 05:00 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I checked all the plug wires to make sure there wasnt a bad one and it was miss firing but everything lookd great.
Ok, before you start tearing stuff apart,...just check the firing order, confirm the correct wires on the correct plugs and terminals,...seen this before, misfire masked as a vibration issue at idle, fine when you get on it,(so it seems) but crappy at idle or low speed cruise...
#1434770
05/13/13 12:44 AM
05/13/13 12:44 AM
RapidRobert
Joe keep us updated with any new developments on this
