23 spline behind a 440 stroker? #143436
10/30/08 08:11 AM
10/30/08 08:11 AM
Adelaide, SOUTH Australia
REDNICK Offline OP
REDNICK  Offline OP
Hi all,
I am building a new engine for my 68 Coronet R/T to replace the current 440 which is fuming a bit more under load than it should.
I was going to re ring the fumey engine and use it in another B Body project I have on the go (That car is an auto )
The Coronet had the 4 speed installed in about 1970, and also has a 3.9:1 8 3/4 rear end.
For the replacement,I am using a 68 block with a 512 Stroker kit and a set of Stealth heads.
Its going to run a shortish duration but high lift cam with 1.6 ratio rockers, headers,Street Dominator and 870 Holley.
People are telling me it will SHRED the 23 spline box and alumimium bellhousing, which so far has given no trouble.
What do you reckon? Go to the expense of an 18 spline or Tremec?
Or just be a bit careful with dropping the clutch?
Someone must have beat on a 23 spline before??
Nick.
Re: 23 spline behind a 440 stroker? [Re: REDNICK] #143437
10/30/08 08:33 AM
10/30/08 08:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The 23 spline can take abuse , even the 18 spline hemi trans can be broken , usually it's 3rd gear .
the bellhousing is more in mind of a clutch explosion , use SFI pieces and a blowshield , but for now you can run the stuff you have .
Re: 23 spline behind a 440 stroker? [Re: REDNICK] #143438
10/30/08 09:13 AM
10/30/08 09:13 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
I would go with a blow proof bellhousing.
Saftey issue. you may never blow a clutch,
but if it does happen you will regret not having one.
The 23 spline is a weak point, the 8 and 3/4 rear
is also a weak point.
If it is for playing on the street you should be fine.
If you are hard hitting it with slicks that's another story.
Re: 23 spline behind a 440 stroker? [Re: REDNICK] #143439
10/30/08 09:25 AM
10/30/08 09:25 AM
iowa
copchaser Offline
copchaser  Offline
iowa
The 23spline will be fine, I would use a scatter shield for safety. If you run a tremec you will be asking for problems. The stock bellhousing will take it but if something comes unglued, say good buy to your foot.
Re: 23 spline behind a 440 stroker? [Re: copchaser] #143440
10/30/08 09:39 AM
10/30/08 09:39 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The stickier the tires the stronger the drive train needs to be.
Re: 23 spline behind a 440 stroker? [Re: 69Cuda340S] #143441
10/30/08 10:31 AM
10/30/08 10:31 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Don't have any first hand experience on your question, Just want to say thats a cool pic
Re: 23 spline behind a 440 stroker? [Re: REDNICK] #143442
10/30/08 11:20 AM
10/30/08 11:20 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Based on first hand experience here is my
You will be okay with what you have, however, Get rid of the aluminum belhousing as soon as you can and get either a scattershield or an oe steel unit. You will break the 8 3/4 before you break the transmission. A 23 spline has been in my car since I bought it new in '68. Never have I broken a transmission. I run slicks when I race and actually pull the wheels every once and a while. The 23 spline is a stout piece. Do what you want, these are just my suggestions based on personal experiences.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 23 spline behind a 440 stroker? [Re: REDNICK] #143443
10/30/08 12:33 PM
10/30/08 12:33 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Hi all,
Nick.
I'm running a 23 spline behind a 472 hemi and a stock Road Runner. The car is street driven. So far I've had no issues other than the no name blocker rings that I put in that causes it to grind every once and while.
I plan on rebuilding it as 3rd gear has always been a bit noisy. Since I have it apart I'll probably upgrade it to 18 spline guts and late model syncro assemblies.
Re: 23 spline behind a 440 stroker? [Re: REDNICK] #143444
10/31/08 07:42 AM
10/31/08 07:42 AM
uk
TiMopar Offline
TiMopar  Offline
uk
The 23-spline can take lots of abuse; thats based on experience of mine and people I've known. However, definately invest in a scattershield!!! ( The factory cast iron Bells weigh a ton and the alloy ones crack )
Re: 23 spline behind a 440 stroker? [Re: TiMopar] #143445
10/31/08 08:41 AM
10/31/08 08:41 AM
Indiana
79_W200 Offline
79_W200  Offline
Indiana
I run a 23 spline in my truck behind a 470 and pull a sled i don't launch like a strip car but its held up
1979 W200 470
Re: 23 spline behind a 440 stroker? [Re: 79_W200] #143446
11/01/08 04:59 AM
11/01/08 04:59 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
A fresh 23 spline is stronger then a Tremec. These were actually labeled heavy duty 4-speeds and the 18 spline is the Severe duty unit. As someone already said you'll break other parts first.
Re: 23 spline behind a 440 stroker? [Re: tecmopar] #143447
11/03/08 10:29 PM
11/03/08 10:29 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
IMO 6500 RPM launches with a 3.09 or 2.66:1 23 spline and slicks in a B-body are fine. If something breaks, it's probably not because the trans isn't strong enough. They used to run them in the pro stock cars in the 60's and early 70's. Keep in mind that whether it's 18 or 23 spline, 8 3/4 or Dana 60, you do get fatigue in parts.
