1984 lean burn #1434018
05/10/13 03:12 PM
05/10/13 03:12 PM
Mashpee,MA
mopar360 Offline OP
Can't start my lawn mower
mopar360  Offline OP
Mashpee,MA
Hey all ive got a 1984 chrysler fifth avenue with the horrible lean burn system...i have 4 barrel intake and carb and also a mallory magnetic breakerless distributor. What els am i going too need too switch this over? Any help is appreciated!
Thanks,
Ethan
All throttle...No bottle! 1979 Chrysler 300 (360) 1984 Chrysler 5th Avenue (318)
Re: 1984 lean burn [Re: mopar360] #1434019
05/10/13 05:08 PM
05/10/13 05:08 PM
P
Paul_Fancsali Offline
P
Easiest is a point distributor converted to pertronix. As far as the intake port match is important carb I would run a mopar Q jet
Re: 1984 lean burn [Re: mopar360] #1434020
05/10/13 05:24 PM
05/10/13 05:24 PM
318 I'm assuming. If the intake has the way larger 360 ports just get the right intake gasket set. What carb? Set the timing marks at 15 BTDC on #1 compression with the magnet dead even with the tooth that places the cap terminal with the #1 wire over the the rotor. You'll need a 4 pin generic Mopar 4 pin ECU from your parts house (A standard Motor Products LX101 is the best if they carry it) & a ballast of ~1 ohm or a bit more & the wireing diagrams are in the archives. I think you can reuse your coil. Holler back if more detail needed. EDIT if you have a 4 terminal ballast parallel wire it along with a 4 pin ECU & you're good. (add a blue loop of wire at the other end of the ballast so both ends have a blue loop of wire)
Re: 1984 lean burn [Re: RapidRobert] #1434021
05/10/13 05:29 PM
05/10/13 05:29 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
Minimum needed is:
Carb (check)
Distributor (check)
ECU & Wiring harness
I "think" the Ballast resistor is different (dual vs single)
Optional/Suggested:
Manifold (check)
Replacement aircleaner setup
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: 1984 lean burn [Re: G_T] #1434022
05/10/13 08:47 PM
05/10/13 08:47 PM
libby mt
lifted85 Offline
lifted85  Offline
libby mt
or go with a HEI swap, a vacuum advance dist, hei module, some wire, an about half hour to a hour to install
drive fast, drive hard, DRIVE MOPAR
Re: 1984 lean burn [Re: lifted85] #1434023
05/10/13 08:50 PM
05/10/13 08:50 PM
Mashpee,MA
mopar360 Offline OP
mopar360  Offline OP
Mashpee,MA
I found ecu and wiring harness on jegs around 80 buck s shipped...is this all I need?
Re: 1984 lean burn [Re: mopar360] #1434024
05/10/13 10:10 PM
05/10/13 10:10 PM
Yes if you have a ballast but WHICH ECU are you considering? You dont want to get an MP orange box. I'd suggest buy the ECU pentastar harness/pigtail seperately then a parts store ECU
Re: 1984 lean burn [Re: RapidRobert] #1434025
05/12/13 10:18 PM
05/12/13 10:18 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
The factory 2BBL kick-down arm will not reach the throttle on a 4BBL carb. You'll either need to find a 4BBL arm off of an AHB (Diplomat cop car), elongate the existing rod, or go with the Lokar cable kit. I chose to elongate the factory rod on my Fifth by cutting it half, threading the ends of the rods, and using a turnbuckle to join them. Doing it this way allows me to make kick-down adjustments without having to get under the car.
