'03 Ram question #1433741
05/09/13 09:58 PM
05/09/13 09:58 PM
Rocky Hill, Ct
Roadcuda Offline OP
Roadcuda  Offline OP
Rocky Hill, Ct
I am going to look at a used '03 Ram that is supposed to have the tow package. Is there a place on the truck where that would be listed and what would the code be for it? thanks
65 Coronet 500 convertible
69 Fury convertible
69 Roadrunner
75 Scamp
14 Ram 1500
18 Jeep Cherokee
www.69roadrunner.net www.plymouthbulletin.com
Re: '03 Ram question [Re: Roadcuda] #1433742
05/09/13 11:49 PM
05/09/13 11:49 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You probably wont be able to find any code on the truck to tell if if is factory equipped with tow package. There are a few things you can look for though to confirm it however. First it should have a 7 way RV connector in the bumper and a 4 way trailer connector under the truck attached to the hitch. The hitch should be part of the rear frame crossmember hoop and should not be bolted to the bumper through the 3 holes in the bumper where you could put a trailer ball. The dealer installed and aftermarket hitches mount this way and are not factory. The last thing to look for is the 4 way plug under the dash by the big bulkhead of wires going through the firewall left of the drivers feet under the dash. This connector is usually blue in color and is used with an adapter harness to easily plug in an electric trailer brake controller if needed. If you are lucky, if it is already plugged in, you might find the harness in the glove box from when it was shipped from the factory. If not, you can get them at the parts store or the dealer. Hope this helps.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: '03 Ram question [Re: 71yelladustr] #1433743
05/10/13 12:26 AM
05/10/13 12:26 AM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
get the VIN and take it to a dealer, parts or service they can run it and print the options or try this web site
www.chrysler.com/hostd/windowsticker/getWindowStickerPdf.do?vin=
put the vin after the = in the url. Make sure to use cap locks. This will show the window sticker, not sure if it will work for an 03 though.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: '03 Ram question [Re: gregsrt] #1433744
05/10/13 06:56 PM
05/10/13 06:56 PM
Rocky Hill, Ct
Roadcuda Offline OP
Roadcuda  Offline OP
Rocky Hill, Ct
Tried it and it didn't work. Thanks anyways!
69 Fury convertible
69 Roadrunner
75 Scamp
14 Ram 1500
18 Jeep Cherokee
