Page 3 of 3 1 2 3
Re: Challenger - Rear Bumper Guards [Re: burdar] #143282
08/21/09 01:06 PM
08/21/09 01:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Are the pieces that go down to the valence incorperated into the rubber bumpers on the longer ones?
No they appear to be separate on both years, 73 and 74.
Re: Challenger - Rear Bumper Guards [Re: Challenger 1] #143283
09/03/09 08:59 PM
09/03/09 08:59 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
A couple of things I learned thru this ordeal.
The rear brackets I had were indeed 70-72 style. I bought a repop bumper and installed it just fine. I did buy the 70-71 rear bumper filler but found out it was $50 wasted since it wasn't needed. The 72-74 tailpanel must be designed different???
As for the front. I did happen to have 71 front brackets. After pulling my 73 brackets to prepare them for drilling I decided to check the 71's. They match up to the outboard holes and the bumperette hole but obviously not the top hole. I installed the 71 brackets with the 73 bumper and just plugged the top holes with a spare pair of bolts. Downside is the inboard holes in the 73 bumper are round and don't have a square for the carriage bolt to engage. It tightened up by friction.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Challenger - Rear Bumper Guards [Re: Challenger 1] #143284
09/04/09 08:22 AM
09/04/09 08:22 AM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Hey, I was considering this for my 74 barracuda. Does most of this thread apply?
Re: Challenger - Rear Bumper Guards [Re: ResQ911] #2818778
09/08/20 09:57 PM
09/08/20 09:57 PM
NM
74fish Offline
74fish  Offline
NM
Quote
Not true. Both front and rear 1972-74 bumpers and brackets move in just fine. For the front. Use the one square hole to mount brackets to framerail and drill a new hole for the other bolt. For rear bumper, cut bumper brackets. Move inward by overlapping and reweld. Works great. Use 1972-74 bumpers, brackets,fillers, everything. Then add 1970-72 bumper guard to fill slots in valance.
Done.
Good tip . Tried the front bumper on my Cuda. Worked great. Haven't done the back bumper not sure if I want to tackle it, wrench
Page 3 of 3 1 2 3
