Re: Drum brake problem driving me nuts! [Re: therocks] #1430882
05/15/13 09:02 PM
05/15/13 09:02 PM
Pennsylvania
67DeLuxe Offline OP
67DeLuxe  Offline OP
Pennsylvania
Changed rear hose. Same problem. About ready to give up. I just took it for a ride. 20 min brakes start to grab. Came home, cracked bleeder, car rolls like a champ. Wtf is causing this pressure to build while I drive?? I have replaced dang near everything!.
Re: Drum brake problem driving me nuts! [Re: 67DeLuxe] #1430883
05/15/13 09:14 PM
05/15/13 09:14 PM
The only thing I can think of is something going on/hanging up with the rear wheel cyls & their linkage
Re: Drum brake problem driving me nuts! [Re: RapidRobert] #1430884
05/15/13 09:25 PM
05/15/13 09:25 PM
Pennsylvania
67DeLuxe Offline OP
67DeLuxe  Offline OP
Pennsylvania
Maybe the wheel cylinders I bought are bad? Got them from Napa. I even took everything back apart and reassembled.
Re: Drum brake problem driving me nuts! [Re: 67DeLuxe] #1430885
05/15/13 10:08 PM
05/15/13 10:08 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Are the shoes on correct?Small front large rear.Are the adjusters on the right sides? Even though they should always hang up.Did you as suggested pull the master away from the firewall a bit and see if they still drag?Did you replace the hardware?Rocky
Chrysler Firepower
Re: Drum brake problem driving me nuts! [Re: therocks] #1430886
05/16/13 07:18 AM
05/16/13 07:18 AM
Pennsylvania
67DeLuxe Offline OP
67DeLuxe  Offline OP
Pennsylvania
I put a shim between firewall and mc. Used a pretty thick metal washer. Took it for a drive.....very little pedal. So little in fact I turned around and came home. Removed thick metal washer and inserted instead some gasket material I cut out. Went for a drive. Much better pedal of course. Went on a route that included plenty of stop signs so I could give the system a real workout. Problem did not reoccur! Could that very little difference in pushrod travel the thickness of a gasket have been the issue like Doc said? Not ready to say all is well quite yet but going on a long drive today so we shall see. I'll be jiggered if that 1/32 " in pushrod length was the problem.
Re: Drum brake problem driving me nuts! [Re: 67DeLuxe] #1430887
05/16/13 12:55 PM
05/16/13 12:55 PM
I think you got it Kudos to the doc & I learned something
Re: Drum brake problem driving me nuts! [Re: RapidRobert] #1430888
05/16/13 04:31 PM
05/16/13 04:31 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Yes if the piston in the master is not allowed to came all the way back, the brakes will hang up because the fluid cannot return to the master.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Drum brake problem driving me nuts! [Re: HemiRick] #1430889
05/16/13 05:16 PM
05/16/13 05:16 PM
P
Paul_Fancsali Offline
P
Back hose is messed up inside
Re: Drum brake problem driving me nuts! [Re: Paul_Fancsali] #1430890
05/16/13 05:24 PM
05/16/13 05:24 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
would that be the same back hose he just changed?
