Re: Opening a cuda trunk lid
[Re: moparmarks]
#142975
10/29/08 12:12 AM
10/29/08 12:12 AM
Posts: 463 IN
polaraholic
IN
It's hard to do and see at the same time but if you take a flashlight and look in there you'll see where the slot that lock rod went into. Find a screwdriver that will fit the slot and you are good to go. I know it sounds easier than it is. I had a 64 Ply that was missing the lock. When I would get it open I would think now I know the trick for the next time. Then I would work my rear off the next time trying to find that slot again. The slot on mine was vertical but there was a slot lower that was horizontal that kept throughing me off and I would try using it by mistake.
[Re: polaraholic]
#142976
10/29/08 12:17 AM
10/29/08 12:17 AM
Posts: 12,528 Western Colorado High Desert
moparmarks
Not on a Cuda. The lock is over by the pass tail light and has a rod that goes to the latch.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#142977
10/29/08 12:23 AM
10/29/08 12:23 AM
Posts: 463 IN
polaraholic
IN
OOPS! But you now know how to get in my Ply so I'm sending the guys in dark suits and glasses to have a talk with you.
[Re: Snoopy]
#142982
10/29/08 12:20 PM
10/29/08 12:20 PM
Posts: 4,800 ILL
MLR426
ILL
If you remove the license plate light lens, you still have the light housing in your way and it is attached from the trunk side.
I know that but you can still gain access to the latch.
logan426
[Re: David Lee]
#142984
10/29/08 02:16 PM
10/29/08 02:16 PM
Posts: 12,431 Looking for a way out of Middl...
IMGTX
Take out the back seat. A little grunting and pulling and it will come out. Then use a couple extra long 2 or 3ft extensions to remove the latch from the rear mount while sitting comfortably in the floor where the back seat used to be. OK so it won't be comfortable but a fat butt like mine can't squeeze into the trunk as easy as I can use a couple really long extensions or a half dozen shorter ones.
