Re: 727 experts
[Re: 2264PLY]
#1429001
05/01/13 10:57 PM
05/01/13 10:57 PM
Posts: 20,149 Park Forest, IL
slantzilla
Park Forest, IL
Pretty sure the '62 has the rear pump and the '65 doesn't. I would think that would make the VB's non interchangeable.
Re: 727 experts
[Re: 62maxwgn]
#1429006
05/02/13 07:03 PM
05/02/13 07:03 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The PB cable works fine in the Column/Console VB but you must use the Column/Console adjustment procedure i.e. the PB adjustment procedure calls for adjusting in the Reverse position and pushing on the cable while the Column/Console procedure is done in 1st while pulling on the cable.
If you use the PB procedure on the '65 you will be one gear off...AMHIK.
