Re: Dougs vs TTI vs Hedman vs Hooker Headers
[Re: Mr.Yuck]
#1428174
04/30/13 03:23 PM
04/30/13 03:23 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
DOUG'S CERIMIC COATED BOUGHT FROM SUMMIT FOR LIKE 600.00 BEST FITTING HEADER EVER,NO MORE BURNED BOOTS AND I CAN EASILY REACH EVERY PLUG WITH OUT TWISTING AROUND, THE FIT IN SUPER EASY BUT YOU MUST USE A MINI STARTER, THESE IN MY 70 RR 440,AUTO,NO PS,I WILL NEVER BUY ANYTHING BUT DOUGS,PM ME IF YOU WANT THE PART NUMBERS AS I'M AT WORK NOW. DARREN
[Re: meepmeep70]
#1428175
04/30/13 05:21 PM
04/30/13 05:21 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
the hookers have great access to all the plugs and I only had to use one "heat shield"
[Re: rapom]
#1428177
04/30/13 08:35 PM
04/30/13 08:35 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Do you want the best fitting header or do you mean the best fitting header with the best price ? I can only tell you the 2" TTI's on my 63 Sport Furys 440/493 are the best headers I have even installed. They were not cheap at $691 big ones but they are the best quality headers I have ever used. Thats not to say the Dougs or Hookers are not as good as I have not used them for years. But I will say the TTI's are definetly a better header then the Hedmans I used. But for the price the Hedmans worked ok and fit good enough as they are an ok header just not as good a quality or as easy a fitting as the TTI's. I would have no problem using the Hedmans if thats what fit my budget as they work fine. I just wanted the best header I could get when I put the 493 in my 63 and in my opinion the TTI's were the best headers I have ever used. As was said thats just my opinion as I still would have no problem using the Hookers or Dougs and even the Hedmans if thats all I could swing. Ron
