Re: MSD Pro Billet Distrubutor
[Re: scrag]
#1427983
04/30/13 01:12 AM
04/30/13 01:12 AM
RapidRobert
With all the different variables from different parts used I'd suggest using the "vacuum gauge method" to find the ideal that YOUR eng needs then with that # in hand shorten the slots to get your desired total (as you know initial + slots = total). Not sure if the big block std 36-38 for total is still valid for a stroker. Then springs then vac adv (if used). I would start at 10 for a mild cam & 15 for a wild cam
[Re: scrag]
#1427985
04/30/13 01:26 AM
04/30/13 01:26 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I wouldn't be surprised if the best setup turns out to be a locked distributor with a retard to start... And if the engine has good tight quench it may only want 30-32 degrees of timing...
