Update: Which Torque Converter? #1427825
04/29/13 09:13 PM
04/29/13 09:13 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
What stall should my torque converter be and what diameter? This is a street car. Any brand suggestions?
70 B body, 440 bored .040 over, closed chambered head with port and polish, big valves, compression in the high 9's, CompCams XE274H cam, 3.91 SG, 727TF.
Comp Cams XE274H Cam Specs
I’m listening.
Re: Which Torque Converter? [Re: Big Bad Bee] #1427826
04/29/13 09:23 PM
04/29/13 09:23 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Lenny at Ultimate will set you up with what you need
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Which Torque Converter? [Re: Eric] #1427827
04/29/13 09:31 PM
04/29/13 09:31 PM
Spokane Valley, WA
Spokane Valley, WA
Is he overkill with a street motor?
I’m listening.
Re: Which Torque Converter? [Re: Big Bad Bee] #1427828
04/29/13 09:36 PM
04/29/13 09:36 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Might be...there may be a good off the self unit for you...
Re: Which Torque Converter? [Re: Big Bad Bee] #1427829
04/29/13 10:16 PM
04/29/13 10:16 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I ran a Hughes 11" 3000 stall for a while with a 440, 3.91 gears in a '67 Dart and eddy heads and headers, with a 245 @ .050 cam and then a 248/254 @ .050 cam. With the second cam, I got boost from going to a 3800 stall 10" converter. But it ran very well with the Hughes with the smaller cam. the Hughes uses a stock flexplate and 5/16" bolts. My new converter uses 7/16" bolts and I went with a B&M flexplate.
If you see more engine upgrades or a bigger cam in your future, you might want to get a 10" 3500 stall now. Otherwise a 3000 stall 10 or 11" should work well with your combo. With a good converter (or maybe it's modern methods that many are using which minimize heat/slippage with street driving), you wont notice a huge difference when you're just doing normal driving until you hammer it.
Hughes was about the cheapest known brand when I was originally shopping. I now have an Edge converter which I really like. Not much more slip than the Hughes in normal driving, but when you get on it, it flashes up around 3800 and you're on your way.
You might hit ebay and the classifieds here to see what people are getting rid of. The edge converter I got is about 650 new, I got it for 380 shipped (shipping is around $50 when I sold my old hughes for $250).
Re: Which Torque Converter? [Re: Big Bad Bee] #1427830
04/30/13 12:00 AM
04/30/13 12:00 AM
Cab_Burge Online work
Cab_Burge  Online Work
Converters are like brain surgeon, don't buy or pay for the cheapest ones Buy the best one you can now so you won't be sorry later Been there, done that
Re: Which Torque Converter? [Re: Cab_Burge] #1427831
04/30/13 12:38 AM
04/30/13 12:38 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
With your combo, just about anything will work. The 3.91 gear and 727 3 speed are doing all the heavy lifting, and the cam is small enough that it really isn't giving much away at the bottom end.
So any of the tons of 11" HS types, typically in the 24-2800, or 28-3200 varieties would work. These typically come in the 200-400$ range.
You driving style, and performance goals also play into the decision. If you are married to the 3.91 gears, You can get away with a 10" or 9 1/2", and up the stall into the mid 3K range, but should you decide to throw in a set of 2.76's or 3.23's for a road trip, you may find the looser converter to be inefficient at least, or a heat building pig at worst!
Just a general tip here, but for Dual purpose cars, converters that are "Tight" for their size tend to work best. For instance a 10" 4500 stall is considered loose, while an 8" 4500 is considered tight.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Which Torque Converter? [Re: MoparBilly] #1427832
04/30/13 12:43 AM
04/30/13 12:43 AM
Arizona
Chris'sBarracuda Offline
Arizona
A very good informative post Billy..
Chris..
Re: Which Torque Converter? [Re: Chris'sBarracuda] #1427833
04/30/13 01:07 AM
04/30/13 01:07 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
try mike from freakshow converters that what i run best price great converter ,tell him ian from oz sent you
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Which Torque Converter? [Re: Ian] #1427834
04/30/13 01:36 AM
04/30/13 01:36 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Three letters. PTC, I'd go with one of their 11" set at 3000 all for 275 plus shipping.. Good people too
Mike
1969 Dodge Dart Swinger
Re: Which Torque Converter? [Re: MikeyT] #1427835
04/30/13 02:00 AM
04/30/13 02:00 AM
Spokane Valley, WA
Spokane Valley, WA
Wow! Great information. I love this forum. Keep the comments coming!
I'm not too sure how I will like the 3.91 gears (I'm sure I will love them at stoplights) I don't how much highway use this car will see, but I may get tired of the low cogs. I kinda wish they were 3.23 or 3.55. I've had passing thoughts about a Gear Vendors OD to fix that issue.
I’m listening.
Re: Which Torque Converter? [Re: Big Bad Bee] #1427836
04/30/13 02:48 AM
04/30/13 02:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A GV is a way to go but if you go with any higher stall
type of conv and in OD you CAN run into a heat condition
since its not locked up.... and a GV cost $3000
for the unit... just some thoughts
Re: Which Torque Converter? [Re: Big Bad Bee] #1427837
04/30/13 05:23 AM
04/30/13 05:23 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think a 2,800-3,200 stall 10" would work good?
Best bet is to just call the converter manufacturers and ask them what they recommend.
Re: Which Torque Converter? [Re: 451Mopar] #1427838
06/12/13 06:39 PM
06/12/13 06:39 PM
Spokane Valley, WA
Spokane Valley, WA
Ok, I've done some digging. I contacted Freak Show, PTC, Hughes and TCI for recommendations. Keep in mind that I told all of them that I was interested in street cruising, that I like to boil the tires on occasion and maybe take a RARE blast down the quarter just to see what it will do.
Recommendations I got:
Freak Show - 10" 3000 stall
PTC - 9.5" 2800-3200 stall
Hughes - 11" 2500 stall
TCI - 10" 3200 stall or 11" 2400 stall depending on what I intend to do with it...
Lane at PTC made the most sense to me. He said this TC would work well at highway speed, around town and really give me punch when I get on it. He is also Jiving with what Billy said earlier about tight for their size torque converters. He actually asked me what intake and carb I was using, which none of the others did.
But contrast that with Hughes, who recommended the 11" 2500 stall. Did this guy compromise on the high end performance to get me street manners?
The weird ball one was TCI. The dude gave me 10" 3200 stall Street Fighter as an answer. When I asked about the street manners of this TC he instantly said, "if you don't want one that loose, the next step down was a 11" 2400 stall Break Away model. It seems like a drastic drop, although after rereading Billy's post, maybe not.
Overall I am leaning toward the PTC but it's more pricy. I wish I could feel what the performance felt like before I buy. The terrifying thing is that I get such varied opinions. I talked to a guy trying to sell his 3000 stall unit. Had it behind a .500 mechanical cammed hemi and it was way too harsh for him. Talked to another old guy who builds race motors and he said anything higher than 2400 is nuts for my combo and I will be unhappy at 3000 stall for the poor street manners and the trans will toast because on the highway I will have to be going 60 mph to get a full lock.
Thanks for bearing with me. More thoughts? I also need a trans master rebuild kit if you guys have suggestions.
Thanks - Lindy
I’m listening.
Re: Which Torque Converter? [Re: Big Bad Bee] #1427839
06/12/13 06:56 PM
06/12/13 06:56 PM
Renton Washington
Triple Threat Offline
Renton Washington
Thanks - Lindy
Get the PTC, you'll be happiest.
This old guy you speak of is a moron. I put thousands and thousands of street miles on a converter that stalled at 4800 rpm. These converters only stall to the rated rpm at full throttle, if you're part throttle cruising around, you'll be totally fine.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Which Torque Converter? [Re: Triple Threat] #1427840
06/12/13 07:10 PM
06/12/13 07:10 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
if it was me, it would be something in the 4000 range 9.5 converter
I'm a huge fan of Lenny @ Ultimate
I put over 400 miles a day on a 5300 stall 9" so don't listen to the old guy
Re: Update: Which Torque Converter? [Re: Big Bad Bee] #1427841
06/12/13 08:26 PM
06/12/13 08:26 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Look at Turbo Action. We've used them for over 35 years,and they have a excellent product.
www.turboaction.com
Nautilus Racing-
Re: Update: Which Torque Converter? [Re: Chris2581] #1427842
06/12/13 09:50 PM
06/12/13 09:50 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
A 9.5" Dynamic is tough to improve on. The hemi CAR I built a trans for, has less torque than you, and was pretty seamless, as far as driveability.
Re: Which Torque Converter? [Re: Big Bad Bee] #1427843
06/12/13 10:44 PM
06/12/13 10:44 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
BBB, Out of the 4 converters you listed, I would go with the PTC. IMO, you are over thinking this abit. Splitting hairs by a couple hundred stall rpm,s or so.
I did the same myself years ago, but with todays modern verts its different. They arent as loose as they used to be.
Meaning, that they dont rev up to stall before the car moves.
If I were you , I would jump right up to a Dynamic 3800 to 4200 stall 9.5" or something similer. They will do everything you are asking and more. Skip the baby steps, IMO
Re: Which Torque Converter? [Re: Sport440] #1427844
06/12/13 11:32 PM
06/12/13 11:32 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
listen to the man
