70 Duster Tail Stripe - Which Version is 'Correct'???? #1427400
04/29/13 10:39 AM
04/29/13 10:39 AM
Colorado
CuriousYella70 Offline OP
Colorado
Okay, when looking at the tail light stripe on a 70 Duster, I've seen the bottom piece done two different ways and cannot figure out which one is correct? Does the 'v' cut in the stripe point down (which makes for a huge gap between the two) or does it point up (which creates less of of you take a look at this one, you'll see how the 'v' cut points down towards the ground and it makes that massive gap between the two stripes.
http://www.pantherpink.com/fm3180g.htm?load_img=7
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: CuriousYella70] #1427401
04/29/13 11:41 AM
04/29/13 11:41 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I had NOS stripes placed on my car back in 1979. The tail stripes are both parallel. I have a complete set of NOS stripes in storage. I will try to dig out the tail stripes and see if they are straight.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: FJR doc] #1427402
04/29/13 12:07 PM
04/29/13 12:07 PM
Port Saint Lucie, FL
ChallengerGary Offline
They installed the bottom stripe upside down in that picture
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: FJR doc] #1427403
04/29/13 12:09 PM
04/29/13 12:09 PM
Colorado
Colorado
Great, thanks! I was informed that they each have a 'v' cut into them so they'll fit on the tail panel better. The upper stripe is pretty self explanatory as the key hole helps determine how the stripe goes on.
It's the lower stripe i'm unsure of. I've seen it installed both ways.
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: ChallengerGary] #1427404
04/30/13 10:48 AM
04/30/13 10:48 AM
Colorado
Colorado
I've seen a lot of them installed this way. Could it be others are copying the FM3 car thinking it's correct?
I'm trying to find an original advertisement on a 70 340 Duster to see if they show the rear stripe but so far, no luck
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: CuriousYella70] #1427405
04/30/13 11:20 PM
04/30/13 11:20 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: pinkduster] #1427406
04/30/13 11:39 PM
04/30/13 11:39 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Original
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: ScottSmith_Harms] #1427407
04/30/13 11:39 PM
04/30/13 11:39 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It had the upper stripe and the sun baked it off, the outline is tough to see but clear, looks just like the lower stripe.
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: ScottSmith_Harms] #1427408
04/30/13 11:40 PM
04/30/13 11:40 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
3
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: ScottSmith_Harms] #1427409
05/01/13 09:31 AM
05/01/13 09:31 AM
Colorado
Colorado
Great, thanks Scott! I figured it would be pointing down but it sure does look odd with that big gap in between the two stripes!
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: CuriousYella70] #1427410
05/04/13 01:35 PM
05/04/13 01:35 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Here's some original rear stripes on a 71 Duster: Also notice the Duster cloud does not say "Duster 340", only "Duster" as this was how they came in 71.
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: Steve340] #1427411
05/04/13 01:39 PM
05/04/13 01:39 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Also notice the Duster cloud does not say "Duster 340", only "Duster" as this was how SOME of them came in 71.
Fixed it for you
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: ScottSmith_Harms] #1427412
05/04/13 01:44 PM
05/04/13 01:44 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Also in 71 only, the 340 callout numbers where part of the lower pinstripe and not separate decals like they were in 72. There where no dust swirl in the rear either in 71.
Re: 70 Duster Tail Stripe - Which Version is 'Correct'???? [Re: Steve340] #1427413
05/04/13 01:45 PM
05/04/13 01:45 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
side by side:
