Another belt question #1427263
04/28/13 11:56 PM
04/28/13 11:56 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I've got the belts mounted and now I'm adjusting them before I cut the excess off. Where do you guys like the cam lock at? I have it adjusted to where it's about at my belt buckle
Re: Another belt question [Re: justinp61] #1427264
04/29/13 12:11 AM
04/29/13 12:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
More of a personal preference... I like my cam lock in
the area about 2" below my belly button... the crotch
strap dictates that height... put the lock on you
gut where it feels best then set the length... check
twice... cut once
Re: Another belt question [Re: justinp61] #1427265
04/29/13 12:44 AM
04/29/13 12:44 AM
Az
Crizila Offline
Crizila  Offline
Az
Got mine adjusted so it sits right over my belly button - same place I wear my pants belt.
Fastest 300
Re: Another belt question [Re: MR_P_BODY] #1427266
04/29/13 01:10 AM
04/29/13 01:10 AM
W. Kentucky
W. Kentucky
Thanks guys it feels good where my belt buckle is, about two inches below my belly button. I just wanted to see what other peoples opinion was before I start cutting. I'll leave enough extra to make sure I can adjust it some more if needed.
Re: Another belt question [Re: justinp61] #1427267
04/29/13 01:17 AM
04/29/13 01:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I cut the belts with maybe 5" of spare length and
I double it back over and use a tie rap or 100 mph
tape to hold it down at the floor mount
