Converting a LU 727 to non LU #1426490
04/28/13 12:09 AM
04/28/13 12:09 AM
Gainesville,FL
goldmember Offline OP
Gainesville,FL
I have a LU 727 that I would use if It can be converted to non LU. Is this doable? What parts and mods are required? Thanks for any feedback from those that have done this. Thanks
Re: Converting a LU 727 to non LU [Re: goldmember] #1426491
04/28/13 04:08 PM
04/28/13 04:08 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
your best bet would be to talk to john at CRT.
Re: Converting a LU 727 to non LU [Re: goldmember] #1426492
04/28/13 04:48 PM
04/28/13 04:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It can be converted to non-lockup; you'll need the reaction shaft support, input shaft, rear clutch piston retainer and valve body from a non-lockup trans.
Re: Converting a LU 727 to non LU [Re: John_Kunkel] #1426493
04/28/13 05:25 PM
04/28/13 05:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You will also need a non lock up converter.
