license pass 1st time in the nines video
#1426308
04/27/13 02:25 PM
04/27/13 02:25 PM
Posts: 251 bonney lake washington
w2stroker
http://www.youtube.com/watch?v=asAmH9EMsQk&feature=youtu.befinally got a chance to make my license passes.it all went good considering it was the first time any cars have gone down the track this year and my slicks have almost 200 passes on them. first all out pass 60' 1.475 1/8 mi 6.408 mph 110.76 1/4 mi 9.969 mph 137.21 second pass in the video 60' 1.409 1/8 mi 6.394 mph 109.60 1/4 mi 9.984 mph 136.26 427 ci small block thank you Brian at imm engine
Re: license pass 1st time in the nines video
[Re: w2stroker]
#1426309
04/27/13 02:32 PM
04/27/13 02:32 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
Awesome with that mph I bet your gonna go quicker
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#1426317
04/29/13 12:39 AM
04/29/13 12:39 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Leave at 4800rpm, shift at 7700rpm. Try that first.
Brian Hafliger
[Re: w2stroker]
#1426318
04/29/13 01:53 AM
04/29/13 01:53 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Your gonna need better shocks on the rear than the Rancho.. your at 9 and still need more control.. time to step up EDIT did you try the rears at about 7
[Re: w2stroker]
#1426320
04/29/13 10:29 AM
04/29/13 10:29 AM
MR_P_BODY
Mike it was at bremerton on friday. Brian i will definatly try that this coming saturday. on the old motor changing launch rpm never changed 60' times it would only change my reaction times, but with the new motor i will try it and see if it helps. Mr P do you have any recomendations on shocks? previous settings of both 5 and 7 have only made the 60' worse.
Well if you tried the lower settings and it got worse then maybe a set of Afco's... it sounds like your shocks just dont have enough control... I have a old set of QA-1s that have 12 clicks but they dont make them anymore
[Re: MR_P_BODY]
#1426321
04/29/13 02:07 PM
04/29/13 02:07 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
To me when I watch your video, it seems like the car has no movement...not much "action" on the line. It needs to pitch rotate more than that. Looks like the front end is too tight on up travel. You need all the stiction out of the front suspension. The rear will never work properly if the front does not picth rotate. Do you know what your weight balance is front to rear?
Brian Hafliger
