Re: FRONT SPRING HANGERS................... [Re: Thumperdart] #1426289
04/29/13 01:21 PM
04/29/13 01:21 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
So...the general consensus is the Mopar Box is too flimsy a deal?
And I saw it was mentioned but I don't recall an answer - is the front spring eye on a Chevy 25" mono leaf the same width as a Mopar leaf? If not, what is the width, and if a different width front bracket needed - heck a different / longer Cal Trac bar needed? If you had the Mopar bar already can it still be used, maybe with a few more parts and pieces, or does it too have to be changed?
I have a Mopar A body Cal Trac bar / Mono leaf set but have yet to install it, nor install any sort of relocation spring box, but this topic has me thinking ahead to maybe considering setting it up ahead of time to accommodate both the Chevy 25" front segment leaf and Mopar leaf, with additional holes, if possible. Better to do it once, one time...
Re: FRONT SPRING HANGERS................... [Re: Sixpak] #1426290
04/29/13 01:32 PM
04/29/13 01:32 PM
State of confusion
Thumperdart Offline OP
State of confusion
The Mopar or similar boxes are fine as many use them and once in place washers can be welded on the outside of the hanger for extra strength. The ft. 25" segment has the same eyelet and sizing as the Mopar one so it just bolts in but moving it 5" foreward is interesting and if you have a plasma cutter, you could cut the time WAY down............pics soon of the butchery then final photos to follow.
Re: FRONT SPRING HANGERS................... [Re: Sixpak] #1426291
04/29/13 03:27 PM
04/29/13 03:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The boxes are only 1/8" material but so is the frame rail. Besides, the holes are close to the rails and crossmembers so there should be plenty of strength there. If the spring eyes were out towards the end of the boxes it would be a whole different story. The boxes are 3-1/4" inside.
Don't cut out both sides of the framerail, notch the rail so one side of the box fits against the inside of the rail which will double the thickness of one side of the box. drill a series of holes in the framerail so you can plug-weld to the box. For an added measure, cut a patch out of the floor so you can weld the box in inside the frame rail. Weld the patch back in when you're done.
Re: FRONT SPRING HANGERS................... [Re: Just-a-dart] #1426292
04/30/13 02:19 AM
04/30/13 02:19 AM
State of confusion
State of confusion
Make your own Dom, thats what I am going to do on the Demon.
My room mate`s going to fab up my boxes tomorrow made to my exact specs from my cardboard templates so wed looks to be d-day on fittin and final welding. Since I can`t make the t&t this fri. we decided to go back to Irwindale next thu. and this time I`ll save te best for a nite pass after 9:00 pm and if all of this works I should run the number........... Thankxxx for the tips.......
Re: FRONT SPRING HANGERS................... [Re: Thumperdart] #1426293
04/30/13 02:33 AM
04/30/13 02:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your first line there is funny.. my exact specs and
cardboard
Re: FRONT SPRING HANGERS................... [Re: MR_P_BODY] #1426294
04/30/13 02:46 AM
04/30/13 02:46 AM
State of confusion
State of confusion
Most patterns are made from cardboard(not box cardboard) first and trust me, this things within an 1/16th all the way around.............don`t see what`s funny about that.............
Re: FRONT SPRING HANGERS................... [Re: Thumperdart] #1426295
04/30/13 02:56 AM
04/30/13 02:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Most patterns are made from cardboard(not box cardboard) first and trust me, this things within an 1/8th al the way around.............don`t see what`s funny about that.............
I've built thousands of parts over the years...
I used a print most of the times... didnt need a
pattern... and 1/8" and exact dont correlate...
I'm just kiddin with you on what you said
Re: FRONT SPRING HANGERS................... [Re: MR_P_BODY] #1426296
04/30/13 02:59 AM
04/30/13 02:59 AM
State of confusion
State of confusion
I meant to say 1/16th and this stuff is thin but very stiff and perfectly squared with a perfectly centered mounting hole. Not sure what print is though............
Re: FRONT SPRING HANGERS................... [Re: MR_P_BODY] #1426297
04/30/13 03:01 AM
04/30/13 03:01 AM
State of confusion
State of confusion
pattern... and 1/16" and exact dont correlate...
Re: FRONT SPRING HANGERS................... [Re: Thumperdart] #1426298
04/30/13 03:05 AM
04/30/13 03:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A fancy drawing of the part in 3 views with all the
dimensions on it... from that you can built the part
(it can have more than 3 views also... some just 2 views)
EDIT
Now days they are CAD drawings or other programs
Re: FRONT SPRING HANGERS................... [Re: MR_P_BODY] #1426299
04/30/13 11:35 AM
04/30/13 11:35 AM
State of confusion
State of confusion
Now I know what you mean.............sat in a CAD class at College.
Re: FRONT SPRING HANGERS................... [Re: Thumperdart] #1426300
05/03/13 09:01 AM
05/03/13 09:01 AM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
How's this project going?
Updates........Pics........
Were you able to buy the front spring segments & longer Caltrac Bar seperately from Calvert?
Brett Miller 447 W9
Re: FRONT SPRING HANGERS................... [Re: mcduff] #1426301
05/03/13 12:22 PM
05/03/13 12:22 PM
State of confusion
State of confusion
We finished it last night so I just need to re-locate my brake and fuel lines, hook up drivers side exhaust and lower and bolt the rear end in place. My room mate made the baddest/srongest boxes I`ve seen yet and yes I bought the chevy/mopar ft. segments and I`m waiting on my friend to take the finished photos so we can post before/after shots but if he can`t make it it`s going back together..........Lot`s of work and crawling on concrete at 52 sucks............
Re: FRONT SPRING HANGERS................... [Re: mcduff] #1426302
05/03/13 02:27 PM
05/03/13 02:27 PM
Missouri
Challenger Offline
Challenger  Offline
Missouri
Id be interested in the part numbers that were used from calvert. THANKS
Re: FRONT SPRING HANGERS................... [Re: Challenger] #1426303
05/03/13 02:39 PM
05/03/13 02:39 PM
State of confusion
State of confusion
LF125-445...............
Re: FRONT SPRING HANGERS................... [Re: Thumperdart] #1426304
05/03/13 05:37 PM
05/03/13 05:37 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
What about the the ajuster bars ? don't they have to be longer ?
Re: FRONT SPRING HANGERS................... [Re: VernMotor] #1426305
05/04/13 02:48 AM
05/04/13 02:48 AM
State of confusion
State of confusion
Yes, they`re 5"`s longer also to compensate. I won`t have this thing on the ground till monday cos I have rehersal then car work so my stuff takes the back burner for now but I`ll let you guys know how it works on the street then maybe the track.
Re: FRONT SPRING HANGERS................... [Re: mopar65] #1426306
05/04/13 09:16 AM
05/04/13 09:16 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Bill at RMS sells a kit for A bodys.Its heavier than the MP one and cheaper also.He runs BBD site.Rocky
Chrysler Firepower
Re: FRONT SPRING HANGERS................... [Re: therocks] #1426307
05/04/13 12:35 PM
05/04/13 12:35 PM
State of confusion
State of confusion
My room mate made mine and they`re definately not goin anywhere..........
