Re: FRONT SPRING HANGERS...................
[Re: Thumperdart]
#1426289
04/29/13 01:21 PM
04/29/13 01:21 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
So...the general consensus is the Mopar Box is too flimsy a deal? And I saw it was mentioned but I don't recall an answer - is the front spring eye on a Chevy 25" mono leaf the same width as a Mopar leaf? If not, what is the width, and if a different width front bracket needed - heck a different / longer Cal Trac bar needed? If you had the Mopar bar already can it still be used, maybe with a few more parts and pieces, or does it too have to be changed?
I have a Mopar A body Cal Trac bar / Mono leaf set but have yet to install it, nor install any sort of relocation spring box, but this topic has me thinking ahead to maybe considering setting it up ahead of time to accommodate both the Chevy 25" front segment leaf and Mopar leaf, with additional holes, if possible. Better to do it once, one time...
[Re: Sixpak]
#1426290
04/29/13 01:32 PM
04/29/13 01:32 PM
Thumperdart
State of confusion
The Mopar or similar boxes are fine as many use them and once in place washers can be welded on the outside of the hanger for extra strength. The ft. 25" segment has the same eyelet and sizing as the Mopar one so it just bolts in but moving it 5" foreward is interesting and if you have a plasma cutter, you could cut the time WAY down............pics soon of the butchery then final photos to follow.
[Re: Sixpak]
#1426291
04/29/13 03:27 PM
04/29/13 03:27 PM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The boxes are only 1/8" material but so is the frame rail. Besides, the holes are close to the rails and crossmembers so there should be plenty of strength there. If the spring eyes were out towards the end of the boxes it would be a whole different story. The boxes are 3-1/4" inside.
Don't cut out both sides of the framerail, notch the rail so one side of the box fits against the inside of the rail which will double the thickness of one side of the box. drill a series of holes in the framerail so you can plug-weld to the box. For an added measure, cut a patch out of the floor so you can weld the box in inside the frame rail. Weld the patch back in when you're done.
[Re: Thumperdart]
#1426293
04/30/13 02:33 AM
04/30/13 02:33 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Make your own Dom, thats what I am going to do on the Demon.
My room mate`s going to fab up my boxes tomorrow made to my exact specs from my cardboard templates so wed looks to be d-day on fittin and final welding. Since I can`t make the t&t this fri. we decided to go back to Irwindale next thu. and this time I`ll save te best for a nite pass after 9:00 pm and if all of this works I should run the number........... Thankxxx for the tips.......
Your first line there is funny.. my exact specs and cardboard
[Re: MR_P_BODY]
#1426294
04/30/13 02:46 AM
04/30/13 02:46 AM
Thumperdart
State of confusion
Most patterns are made from cardboard(not box cardboard) first and trust me, this things within an 1/16th all the way around.............don`t see what`s funny about that.............
[Re: Thumperdart]
#1426295
04/30/13 02:56 AM
04/30/13 02:56 AM
MR_P_BODY
Most patterns are made from cardboard(not box cardboard) first and trust me, this things within an 1/8th al the way around.............don`t see what`s funny about that.............
I've built thousands of parts over the years... I used a print most of the times... didnt need a pattern... and 1/8" and exact dont correlate... I'm just kiddin with you on what you said
[Re: Thumperdart]
#1426300
05/03/13 09:01 AM
05/03/13 09:01 AM
Posts: 89 Woodbury, CT.
mcduff
Woodbury, CT.
How's this project going? Updates........Pics........
Were you able to buy the front spring segments & longer Caltrac Bar seperately from Calvert?
Brett Miller 447 W9
[Re: mcduff]
#1426302
05/03/13 02:27 PM
05/03/13 02:27 PM
Posts: 221 Missouri
Challenger
Missouri
Id be interested in the part numbers that were used from calvert. THANKS
[Re: mopar65]
#1426306
05/04/13 09:16 AM
05/04/13 09:16 AM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
Bill at RMS sells a kit for A bodys.Its heavier than the MP one and cheaper also.He runs BBD site.Rocky
Chrysler Firepower
