Re: Alternator Grounding
[Re: jeebis44]
#1425060
04/25/13 12:13 AM
04/25/13 12:13 AM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
OK - This is in a relatively stock car, used for daily driving. Rubber mounts are intact, and using a multimeter, found continuity between the alt. case and engine in several points without the ground wire hooked up. That said, I did upgrade the ground wire years ago to about an 8 gauge wire... would like to keep it that way, if for no other reason than vibration may cause issues down the line ( i drive the thing like a a maniac...). Main point of my original question was to find out exactly WHAT needs to be grounded here, and from all posts to now, it's the case. Simple fix IMHO. Tap and screw into the original ground hole in the case and hook up my HD ground wire going right into the pass. side cyl. head. Am I wrong?
You're correct. There is nothing wrong in your fix!
[Re: jeebis44]
#1425061
04/25/13 12:30 AM
04/25/13 12:30 AM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
You need to ground it as I have said. You will find continuity with a multimeter only because it is finding it through incorrect sources. When you load it the loss of ground will be obvious. That alternator will not work through isolators. You are on the right correct path by using the ground wire to the case. I am done with this post and wish you luck. As far as the uneducated stupid posters that want to argue when they are wrong carry on. I laugh all day long at fools like you.
[Re: jeebis44]
#1425063
04/25/13 12:52 AM
04/25/13 12:52 AM
Pacnorthcuda
What I am reading from these posts is this: ground the alternator case to the engine and the engine to the frame via direct heavy connections (metal-metal heavy gauge wires).
Pre 80's it was usually grounded vis a the mounting of the unit. If the alternator has isolated mounts then either a mount needs to be electrically bypassed or the grounding stud utilized by wiring to a suitable ground, preferably the engine. You are good to go.
[Re: NITROUSN]
#1425064
04/25/13 11:48 PM
04/25/13 11:48 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Thanks for the replies. So then, I should be able to check for continuity between the case and the engine block and if it's there, I'm good?
No.. You want to use a heavy guage wire from that stud to the engine. All the factory cars and trucks had a ground wire. You alternator is mounted with rubber isolators thats why there was a HD wire on the car. I would ask for another correct alternator.
Yep that is dead on right. It needs the ground wire because of the rubber mounts on the alt. Most alt bolt right to the block but some such as this use rubber mounts and need the ground wire. You just have to ground the alt case. Ron
[Re: jeebis44]
#1425067
04/26/13 10:44 AM
04/26/13 10:44 AM
Posts: 1,822 Colorado
denfireguy
Colorado
The problem here is that a lot of people have never seen a cop car alternator. Having rebuilt several of these in the day, what Nitrous is saying is spot on. The only way to get a high current connection is through a 10 gauge (8 is way better) direct to the block. I have not seen a cop car alternator in the rebuilt market. That is why we did our own in the day. The only wear items are the bearings, brushes and diodes. When we had a bad alternator, we shot gunned them and replaced all of the above parts. We did have one with a short in the stator and we took that to a motor winding shop (try to find one of those today) to be redone. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
