Eastwood sound deadening mats #1424955
04/24/13 12:51 PM
04/24/13 12:51 PM
Mid Michigan
Coronet-R/T-Rag Offline OP
Mid Michigan
Eastwood sells an inexpensive version of the Dynamat product. I've read the reviews and it seems that they work good but melt under high temps? Anyone used them? What's your experience?
http://www.eastwood.com/eastwood-thermocoustic-material.html
Re: Eastwood sound deadening mats [Re: Coronet-R/T-Rag] #1424956
04/24/13 01:01 PM
04/24/13 01:01 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
I'm curious also. I will be needing some.
Re: Eastwood sound deadening mats [Re: B1arno] #1424957
04/24/13 01:08 PM
04/24/13 01:08 PM
Madill Oklahoma USA
K
kendalljones Offline
K
Madill Oklahoma USA
I have heard mixed opinions on the Eastwood mats. You are correct, the problem is the ability to withstand the heat Dynamat does. I ended up using the Dynamat because of the fact I have used it before and works well. I kinda go by the, "You get what you pay for." If the mufflers are close, or something that makes a lot of heat, MAY be a problem. I will be watching to see if anyone has used it before.
Re: Eastwood sound deadening mats [Re: kendalljones] #1424958
04/24/13 02:49 PM
04/24/13 02:49 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I am also interested in adding some type of sound deadening mat in my car. I searched for a thread I started sometime ago regarding the same thing, but gave up when I couldn't find it.
My 70 Charger is fine for short trips but once you drive for more than 45 minutes to an hour, the noise and drone tend to wear on me. I am leaning heavily toward Fat mat. Amazon sells a roll that is 1 ft wide, 50 ft long and 80 mils thick. $93. I figure that 2 rolls will cover the whole floor, package tray, trunk divider and behind the door and kick panels. If it only reduces the interior noise by 15-20%, I'd consider that a win.
Re: Eastwood sound deadening mats [Re: Kern Dog] #1424959
04/24/13 03:08 PM
04/24/13 03:08 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Re: Eastwood sound deadening mats [Re: nomore65BelvJim] #1424960
04/24/13 03:56 PM
04/24/13 03:56 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The cheapest way that I know of is to use Modified bitumen rolled roofing and a layer of bubble foil insulation. Find a commercial roofer and ask to buy some scraps or cut-off ends from a roll. Or buy a whole 39"x 33' roll at a commercial roofing wholesaler for about $80. The bubble insul is about $14 at Menards.
I did this on my 67 Olds 442, and was amazed at how effective it was. Much quieter and cooler than before. I didn't even cover the hump or the doors. I just made sure to get the firewall really well and the floor pans. Since it is a convert, I din't know if I would notice any sound deadening because of wind noise, but it was very noticable.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Eastwood sound deadening mats [Re: Hemi_Joel] #1424961
04/24/13 05:47 PM
04/24/13 05:47 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The roofing type matting is a cheap alternative but every testimonial that I have heard involves an odor of the tar imbedded in the mat. Some say it went away within a few days, others say it is still there after a year. If you don't have an overly sensitive nose, this may be a great option.
Re: Eastwood sound deadening mats [Re: Kern Dog] #1424962
04/24/13 08:05 PM
04/24/13 08:05 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I just used the eastwood mats...Did a complete floor...As with all of these types of mats they're heavy !!! Added alot of weight quick...So far so good...No odor with the mats that I could tell and the dual exhaust has'nt created any melting issues I'm aware of...I did break the cheezy roller supplied with the kit in short order and stepped up to a better one...And the edges were sharp and unforgiving during the install...
Eastwood just had a sale on the mats...
Re: Eastwood sound deadening mats [Re: screamindriver] #1424963
04/25/13 09:39 AM
04/25/13 09:39 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I did the "Fat Mat" stuff off ebay, covering the complete floor, hump, firewall, rear wheel well part that is in passenger compartment, and the package tray . . . WOW !!! Can certainly tell the car is quieter inside, and you can barely hear the wonderfull exhaust sound . . . so, I say it is worth the effort to install and the little bit (ok, maybe more than a little) of added weight !!!
I also noticed the heat was way down too !!! I had run the engine without the mat installed and noticed how warm the tranny tunnel got - nothing now with the mat installed !!!
I think for the money, the fat mat stuff, is worth it !! As far as it melting or coming unglued . . . can't say as I have gotten things that warm !!!
Cheers
Mark
Re: Eastwood sound deadening mats [Re: a12rag] #1424964
04/25/13 11:41 AM
04/25/13 11:41 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I know some here are weight consious. A good place to look for lightweight sound deadining products is the aircraft industry. Costs more but in some cases definitely worth it. Just some food for thought.
Getting old just means you were smarter than some and luckier than others.
Re: Eastwood sound deadening mats [Re: Coronet-R/T-Rag] #1424965
04/26/13 01:29 AM
04/26/13 01:29 AM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
2 boxes in my dart convertible. I did inside doors, floors firewall, inner rear quarters, basically everywhere i could. No problems melting. Im in az, and been out in 110F with the asphault temps likely in the 150s. AC kept the car reasonable comfortable. As far as sound deadener quality, worth the weight. Mine is a cruiser so i wanted comfort over power. Ive got heat shields on the mufflers and so far no melting of the insualtion. Stuff is easy to work with, and makes a world of difference.
I wouldnt definately do it again.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: Eastwood sound deadening mats [Re: dannysbee] #1424966
04/26/13 01:40 AM
04/26/13 01:40 AM
Aircraft Spruce and Specialty Co. sound proofing link.
Also this looks good too, from RAAMaudio
Re: Eastwood sound deadening mats [Re: Hemi_Joel] #1424967
04/26/13 02:41 AM
04/26/13 02:41 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I have a roll of that stuff and was thinking of using it as well.
Would it be "ok" to spray undercoating onto the floor pans to not only seal them good but reduce noise as well? Wasn't sure about the fire risk.
Re: Eastwood sound deadening mats [Re: Coronet-R/T-Rag] #1424968
04/26/13 09:31 AM
04/26/13 09:31 AM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
I used this in my Challenger floor. Didn't add too much weight but made a difference in db in the cabin. Good "bang for the buck"...
http://www.audimutesoundproofing.com/how-to-soundproof-a-room-soundproof-walls-sound-insulation.aspx
Re: Eastwood sound deadening mats [Re: Mapandjlp] #1424969
04/26/13 09:59 AM
04/26/13 09:59 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Looks good, what adhesive did you use/
Thanks, Joe
Re: Eastwood sound deadening mats [Re: jlatessa] #1424970
04/26/13 10:28 AM
04/26/13 10:28 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
http://www.b-quiet.com/compare.html these folks seem to be getting good reviews.
Re: Eastwood sound deadening mats [Re: jlatessa] #1424971
04/26/13 06:26 PM
04/26/13 06:26 PM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
Thanks, Joe
If you're asking me, I didn't use adhesive. Just laid it out on the floor and put the carpet over top. It stays in place pretty well as it's a pretty non-slick material. IIRC, it's made from recycled tires.
Re: Eastwood sound deadening mats [Re: Coronet-R/T-Rag] #1424972
04/28/13 06:38 AM
04/28/13 06:38 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My unused Eastwood 36 sq ft mat kit is for sale. For you only a special deal - half price. Waaay too heavy. You pay the freight. No refunds.
