Page 2 of 3 1 2 3
Re: Tubular UCA'S to much? [Re: Keith Black®] #1423527
05/14/13 09:31 AM
05/14/13 09:31 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I like others have put off this purchase. I have have a question. All the upper arms that I have seen other than the OEM and FF upper arms have no provision with working with the upper control arm bumper. This may be a stupid question, but how important is this feature?
Our control arm uses upper and lower bump stops.
The Hotchkis UCA's are slick. I'm looking to replace my FF UCA's with these.
DarrenB,
Not questioning your thinking...but want to learn more about these arms.
If you already have FF arms, what is it about the Hotchkis pieces that is so appealing that you would want to change them?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Tubular UCA'S to much? [Re: DynoDave] #1423528
05/14/13 10:09 AM
05/14/13 10:09 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Some UCA's require notching away sheet metal to install them for clearance (Hotchkis). This is the one reason I won't run them on my car, I only want to add completely reversable upgrades to my car.....
Re: Tubular UCA'S to much? [Re: DynoDave] #1423529
05/14/13 10:14 AM
05/14/13 10:14 AM
Santa Fe Springs, CA
Dan@Hotchkis Offline
DarrenB,
Our control arms not only shift the ball joint location like most of the other arms on the market, our re-located pick up point also improves camber and bump curves drastically. That with both the heim joints allows for a fully adjustable setup.
Re: Tubular UCA'S to much? [Re: ScottSmith_Harms] #1423530
05/14/13 10:20 AM
05/14/13 10:20 AM
The material removed is minimal; non-structural and not visible once the car is assembled.
Re: Tubular UCA'S to much? [Re: Dan@Hotchkis] #1423531
05/14/13 01:13 PM
05/14/13 01:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Would it be visible of the stock arms were put back on?
Re: Tubular UCA'S to much? [Re: ScottSmith_Harms] #1423532
05/14/13 01:42 PM
05/14/13 01:42 PM
You would be pretty hard pressed to notice or find the missing metal if ground properly. I am fairly confident that the modification would not harm the perceived value of our cars.
Re: Tubular UCA'S to much? [Re: Dan@Hotchkis] #1423533
05/14/13 05:27 PM
05/14/13 05:27 PM
QLD Australia
Keith Black® Offline
QLD Australia
DynoDave., its the relocation of the pivot point and resulting camber adjustment that is appealing. I have a ton of other modifications as well so I feel they will work well with my combo.
Darren Beale
Keith Black Racing Engines®
Re: Tubular UCA'S to much? [Re: Dan@Hotchkis] #1423534
05/15/13 11:31 AM
05/15/13 11:31 AM
central CT
cudazappa Offline
cudazappa  Offline
central CT
IIRC that's only for E-bodies. The A-body UCA doesn't involve any modification.
1971 Challenger
Re: Tubular UCA'S to much? [Re: cudazappa] #1423535
05/16/13 01:13 AM
05/16/13 01:13 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Now that's something I had not heard! Are you certain of this?
Re: Tubular UCA'S to much? [Re: ScottSmith_Harms] #1423536
05/16/13 02:36 AM
05/16/13 02:36 AM
Correct. The B and E's in just to clear the relocation bracket's hardware.
Re: Tubular UCA'S to much? [Re: Dan@Hotchkis] #1423537
05/16/13 12:45 PM
05/16/13 12:45 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Awesome I'm back in for some then
Re: Tubular UCA'S to much? [Re: cudazappa] #1423538
05/16/13 02:12 PM
05/16/13 02:12 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The little lip was cut on my A-body for the Hotchkis A-Arms for installation. I have pics I can show later.
I believe it is covered in the instructions if you download and read them.
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Tubular UCA'S to much? [Re: autoxcuda] #1423539
05/18/13 02:05 PM
05/18/13 02:05 PM
southern Idaho
moparcyco Offline OP
southern Idaho
Well after stewing on this awhile I dedided to bite the bullet and bought the firm feel UCA'S I really like these guys and have always treated me well.Will get the m painted to match my combo and installed this weekend.Also decided to up my torsion bars to 1.00 units should make for an awesome cruiser!Thanks everyone
Re: Tubular UCA'S to much? [Re: moparcyco] #1423540
05/31/13 02:02 AM
05/31/13 02:02 AM
moparAL Offline
moparAL  Offline
This is for you autoxcuda. I came across these on e-bay. They were interesting and super adjustable.
Re: Tubular UCA'S to much? [Re: moparAL] #1423541
05/31/13 03:09 AM
05/31/13 03:09 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
are they custom made? do you have the link? edit i found it:
http://www.ebay.ca/itm/B-E-Body-Adjustab...r#ht_823wt_1141
Re: Tubular UCA'S to much? [Re: dangina] #1423542
05/31/13 05:53 AM
05/31/13 05:53 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
The idea of unprotected Heim joints on the street seems risky to me.
Re: Tubular UCA'S to much? [Re: Jjs72D] #1423543
05/31/13 09:51 AM
05/31/13 09:51 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
A-Body
A-body Aluminum
Interesting stuff!
Re: Tubular UCA'S to much? [Re: moparAL] #1423544
06/01/13 09:40 PM
06/01/13 09:40 PM
Here
jcc Offline
jcc  Offline
Here
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: Tubular UCA'S to much? [Re: jcc] #1423545
06/01/13 10:03 PM
06/01/13 10:03 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I don't think I would run those in aluminium.
A new iron curtain drawn across the 49th parallel
Re: Tubular UCA'S to much? [Re: 67autocross] #1423546
06/01/13 10:48 PM
06/01/13 10:48 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
All those parts are common in circle track racing( not expensive) and made from steel usually. I have never seen them in aluminum?
edit: I see what your saying now
http://www.ebay.ca/itm/A-Body-ALUMINUM-u...=item48556cea42
That's just plain dumb!
Page 2 of 3 1 2 3
