Re: Tire shake during burnout [Re: Bad340fish] #1423118
04/23/13 11:44 PM
04/23/13 11:44 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
check Yoke on rear ..
Re: Tire shake during burnout [Re: Bad340fish] #1423119
04/23/13 11:54 PM
04/23/13 11:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Didn't you go from a 6.17 to a 4.10? Thats a huge difference in tire speed if all else is the same.
that is a big change but if he was running a 33" tire
and dropped to a 28" thats 103.6 down to 89 so thats
part of the difference IF he does change sizes...
which I dont know
Re: Tire shake during burnout [Re: Leon441] #1423120
04/24/13 09:36 AM
04/24/13 09:36 AM
an8sec70cuda Offline
Leon, we ran into a similar situation w/ the Camaro (436" SBC w/ a glide) I drive for a friend. Had a vibration at about 1/2 track that'd go away on the gear change. Car otherwise ran great, no vibration in the burnout that I could feel though. Turned out to be the front pinion bearing going bad. Changed it and the vibration went away.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Tire shake during burnout [Re: an8sec70cuda] #1423121
04/24/13 11:06 AM
04/24/13 11:06 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Not sure if I understood the question right,but if its on the burn-out with the Pro-Mods running they might have prep the starting line & track a little better than it was 2 weeks ago.If it is doing it at the end of 1st gear going down the track I would think it was in the drive train,not the tires.A Hi-Horse-Power light weight car can spin the tires & cause a shake,but most times they do it at the torque peak.
PS just for the hell of it jack the rear end up,get you a coffee can tape a piece of soap stone on the top of it and set it close to your rear tires and see if one of your tires has got out of round.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Tire shake during burnout [Re: MRMOPAR622] #1423122
04/24/13 08:06 PM
04/24/13 08:06 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I have not balanced my tires in years and they never shake in the burn out . How are your rear shocks and where do you have them set , if they are set too soft or soggy they can cause the rear end to oscillate and go from a slight vibration to a full on paint shaker . The tire is going into a old fashioned wheel hop caused by traction and lack spring dampener VS rear end wrap up and release . I see this all the time with bracket cars with entry level shocks or older shocks .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Tire shake during burnout [Re: MR_P_BODY] #1423123
04/25/13 05:26 PM
04/25/13 05:26 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
which I dont know
Did not change the tire it is the same 31" tire I have ran for years. Yes, it is a huge rear gear change.
Re: Tire shake during burnout [Re: MRMOPAR622] #1423124
04/25/13 05:28 PM
04/25/13 05:28 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
My car had no vibration down track. That is what another guy posted.
Leon
Re: Tire shake during burnout [Re: go green] #1423125
04/25/13 05:34 PM
04/25/13 05:34 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
This car has a 4-link all moly round tube back half. There are no leaf springs to wrap up. The rear shocks are Santhuff double adjustable. They are old but have never leaked according to Santhuff they are in great shape. They are set fairly soft(8 clicks from tight) which may turn out to be a problem with the lack of torque using the 4.10 gear. We have never been able to run them any tighter than 5 clicks out on the bottom. Would have to check or look in my old log books to see where the extension is set.
I think the rear Yoke deserves rechecking. As well as some other things.
Re: Tire shake during burnout [Re: Leon441] #1423126
04/26/13 02:24 PM
04/26/13 02:24 PM
Marysville Wa
moparfan Offline
moparfan  Offline
Marysville Wa
My Olds will shake the tires in the burn out if I don't have enough RPM,i'm referring to doing across the line burnout. If I do my burnout at 6k it will shake the fillings out of my teeth. Not sure if your stationary in the burnout Leon or going across the starting line. I try to keep the RPM around 6500 in the burnout. The car has a 632, glide and 4.10s with a 33 X 16 tire.
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: Tire shake during burnout [Re: moparfan] #1423127
04/26/13 11:01 PM
04/26/13 11:01 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
It was happening both ways.
I always start the burnout stationary. When I am in my groove I get the tires rolling then pump the line lock botton so the car can pull out on its own without overrevving.
Once I got in the groove I just ignored the shaking which was reduced because I set the chip at 7,500 to try and elliminate the shake.
Maybe the tires were hot enough and I should have been just pulling ahead.
Leon
Re: Tire shake during burnout [Re: Leon441] #1423128
04/26/13 11:10 PM
04/26/13 11:10 PM
Marysville Wa
moparfan Offline
moparfan  Offline
Marysville Wa
Not sure same issue as mine, mine starts the shake because the tires are trying to hook (what if feels like anyway)I lift when it starts doing it. I did have an issue last year, the first time out (prior seasons tires on still) the car shook badly in the burnout and all the way down. I took the tires to the tire shop and they rebalanced them. Shake (vibration) was gone after that. I always leave the car up on the jacks so it surprised me the tires changed over the winter As far as balancing, i've never been lucky enough to not have to balance them, have always vibrated when I didn't.
2021 T/A 392
2020 Hellcat redeye
Re: Tire shake during burnout [Re: moparfan] #1423129
04/27/13 11:25 PM
04/27/13 11:25 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Ran the car today with the 6,17 gear; Very little shake. But, noticed a small vibration momentary in the run.
Re: Tire shake during burnout [Re: Leon441] #1423130
04/28/13 02:55 AM
04/28/13 02:55 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I would think shocks being worn would be the culprit if the car runs clean down the track. A loose of worn heim maybe.
Mopar to the bone!!!
