Page 4 of 5 1 2 3 4 5
Re: 4-Speed Shifter Install Clearance Issues [Re: JohnRR] #1421045
04/25/13 03:21 PM
04/25/13 03:21 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Just adding some info for people....
Z BAR TO PEDAL RODS
APPLICATION INSIDE -INSIDE HOLE NOTES
62-5 B-BODY 14 3/4” BEND IN MIDDLE
66-70 B-BODY 12” BEND IN MIDDLE
67-UP A-BODY 12 1/2” OFFSET AT END
E BODY + 71-UP B-BODY 13 1/4” OFFSET AT END
SHIFTER MECHANISMS
E-BODY #7180 ON REV ROD
70 B-BODY #7174 ON REV ROD
A/B-BODIES #6353 ON REV ROD
SHIFT ROD LEVERS
1-2 3-4 REV
67-74 A-BODY HURST 891 890 967
63-8 B-BODY INLAND ROW DIR REV
68-74 B-BODY HURST 891 890 967
71-4 B-BODY BENCH 147 146 148
E-BODY 058 057 368
SHIFT RODS
A-BODY 62-70 B-BODY E-BODY 71-4 B-BODY BENCH
REV ROD 16” 7 1/2 25” 13 1/2”
1-2 ROD 13 1/2” 6 1/4” 17 3/4” 12”
3-4 ROD 17 1/4” 10 1/2” 22” 16 1/4”
ALUMINUM SHIFTER ADAPTER PLATES
68-70 B-BODY #6348
68-76 A-BODY #6350
64-65 A-BODY #2298
* INLANDS HAVE NO NUMBER
BIG BLOCK A-BODY Z-BAR 5 5/8 tube, short arm 4 3/4, long arm goes out and up 5 1/2
Re: 4-Speed Shifter Install Clearance Issues [Re: Cuda340] #1421046
04/25/13 11:01 PM
04/25/13 11:01 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
Hi Folks.
Well, the 6350 plate is installed and it really helped my clearance issues. Still working through getting the rods adjusted.
I've taken some measurements and pics for anyone that cares.
2298
383, Hemi 4-Speed, AlterKtion, D60
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421047
04/25/13 11:02 PM
04/25/13 11:02 PM
Canton, Ohio
Canton, Ohio
6350
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421048
04/25/13 11:03 PM
04/25/13 11:03 PM
Canton, Ohio
Canton, Ohio
front
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421049
04/25/13 11:03 PM
04/25/13 11:03 PM
Canton, Ohio
Canton, Ohio
back
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421050
04/25/13 11:27 PM
04/25/13 11:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Looks like the 6350 plate moves the shifter up , back and out some . a stock set of rods would probably fix the clearance issues .
Re: 4-Speed Shifter Install Clearance Issues [Re: JohnRR] #1421051
04/25/13 11:45 PM
04/25/13 11:45 PM
Canton, Ohio
Canton, Ohio
Yep. It moves it around a good bit.
Yeah, probably correct on the stock rods. The hump location is still fine with the 6350 plate.
I've sent a PM to Gus. I have what I think a good neutral adjustment, but I am not able to move through the gears. Trans in neutral, and 3/16" allen wrench through slot and all three plates. Stick floats in neutral left to right.
Had my wife move 1/2 and 3/4 what little it will and the rods are not hitting anything or each other. Just seems like something is bound up. I can go into reverse and that locks the driveshaft, back out of reverse and into neutral can then spin the driveshaft again.
Just realized... maybe I need to readjust the stops? Gus adjusted them, but that was with the old 2298 and different rod adjustment...
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421052
04/25/13 11:46 PM
04/25/13 11:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The alignment hole in the shifter should be 1/4" .
Check and make sure reverse isn't causing your problem.
Re: 4-Speed Shifter Install Clearance Issues [Re: JohnRR] #1421053
04/26/13 10:25 PM
04/26/13 10:25 PM
Canton, Ohio
Canton, Ohio
Adjusted with 1/4. Same issue. Reverse does not appear to be the issue. It is in the forward position (i.e. neutral). I can grab and spin the driveshaft, no problem. I can engage reverse, no problem, drive shaft will not spin. Can come back out of reverse into neutral.
Still cannot get in any gear 1-4, it is like the forks are hung up, jammed, or something. Shifter plates move free and clear, it is not the stops.
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421054
04/26/13 10:58 PM
04/26/13 10:58 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Well it's time to drop the rods off the transmission arms and try shifting the transmission through the gears with a wrench on the arms, they should move freely. if not you probably have a syncro problem.
Re: 4-Speed Shifter Install Clearance Issues [Re: rowin4] #1421055
04/26/13 11:07 PM
04/26/13 11:07 PM
Canton, Ohio
Canton, Ohio
Did that. How much force on the levers is needed? I assume not very much. They both move slightly each way but that is it. Would rotating the engine be worth anything?
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421056
04/27/13 09:44 AM
04/27/13 09:44 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Andy I have time Sunday If you still have my number give me a buzz and I will stop over to straighten out your shifter issues.
I sent you a PM with my number.
Gus
64 Plymouth Savoy
Dana 60
Re: 4-Speed Shifter Install Clearance Issues [Re: fourgearsavoy] #1421057
04/27/13 10:13 AM
04/27/13 10:13 AM
Canton, Ohio
Canton, Ohio
Gus, I got your PM, and thank you. I hate to have you drive the whole way down here. I'll send you a text and give you a call. Maybe we can talk through this.
Tomorrow is better for me as well.
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421058
04/27/13 10:51 AM
04/27/13 10:51 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Those are the heavy-duty Hurst linkages for race shifters, I have been looking for a set of those for a while now! Let me know if you want to trade for a factory set!
Rhino, this statement above?
I'm sorry, I guess I misunderstood. I was supposed to understand by the above reply that these were Hemi Dart rods? Anything beyond the stock rods seem to be considered "heavy duty". That and the fact that you seem to know that there was a one-off plate for these rods was not mentioned until lately. Oh well.
Before I do anything else to these rods, *are* these original Hemi Dart rods or are they after market? I understand that since they are Hurst they are technically after market and not original Chrysler. I just want to understand their value. <jab>Probably a little more than the stock ones you wanted to trade me for?</jab>
John, yeah, I agree. I've barely messed with them. Over the years, it is hard to say if these were every tweaked before or not. Either way, 30 seconds and they are back to where there were. What I have done so far will only help with the new plate when comparing the mounting position against the one I have.
Brewers said I would have the plate today. I just want to drive this car...
Thanks guys.
Sorry about being cryptic, I forgot half the stuff I used to know 10 years ago! It seems that the plate you just got resembles the Hemi Dart plate, I will have to get out the guide to check it for sure. The rods you have are aftermarket Hurst and were designed for the Hemi Dart and other race applications. There are heavy-duty rods for each Mopar trans and what you have are the A-Body rods. I sold a set of E-Body rods like yours for $125.
JB Rhinehart, Realist
A-Body's RULE!
Re: 4-Speed Shifter Install Clearance Issues [Re: Rhinodart] #1421059
04/27/13 11:14 AM
04/27/13 11:14 AM
Canton, Ohio
Canton, Ohio
Rhino, no problem. I understand. No harm no foul.
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421060
04/27/13 03:23 PM
04/27/13 03:23 PM
Canton, Ohio
Canton, Ohio
, me again.
Pulled everything back apart. Installed just the levers (upside down so I can reach them and get vise grips on them). I can get into all 4 gears if and only if I spin the driveshaft back and forth at the same time. Very "notchy" feeling.
I don't have any lube in this thing, never driven it since it was rebuilt. Maybe put in the Synchromesh twirl it a few times and see if that helps?
Or does it sound like I have a problem?
Thanks.
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421061
04/27/13 03:25 PM
04/27/13 03:25 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Get some oil in that thing and spin it. It WILL help. The stop rings and gears are unlikely to be lined up and unlikely to be forced into alignment dry.
Re: 4-Speed Shifter Install Clearance Issues [Re: Jim_Lusk] #1421062
04/27/13 04:39 PM
04/27/13 04:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421063
04/27/13 07:43 PM
04/27/13 07:43 PM
Rittman Ohio
Rittman Ohio
All the gears and sliders have some heavy assembly lube on them and some of the rings may be stuck to the hub on the gear.Make sure you push the clutch in before you try testing the shifter into the gears.
When you want to circulate the fluid put the trans into 4th gear,have someone hold the clutch in while you turn the driveshaft/wheels.That way it will coat the cluster and all the drive gears when they rotate through the lube.
I will call you tomorrow to see how it's going
Gus
64 Plymouth Savoy
Dana 60
Re: 4-Speed Shifter Install Clearance Issues [Re: fourgearsavoy] #1421064
04/27/13 11:37 PM
04/27/13 11:37 PM
Canton, Ohio
Canton, Ohio
Gus
Good deal. I'm glad what I am seeing makes some sense. Onward and upward.
While we are on the topic of 4-speeds... , can I get GL-4 gear lube at an auto parts store? Was going to use synchromesh, but then I made the mistake of doing a search on the forum... lol. Was thinking about a mix of synchromesh and gear lube. Some have had issues with synchromesh leaking? I know some guys run ATF, but I am not interested in trying that. Just my preference I guess... seems like gear lube belongs in gear boxes. Again, I am probably over-analyzing.
