Page 2 of 5 1 2 3 4 5
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421005
04/17/13 05:40 PM
04/17/13 05:40 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
reverse rod
383, Hemi 4-Speed, AlterKtion, D60
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421006
04/17/13 05:41 PM
04/17/13 05:41 PM
Canton, Ohio
Canton, Ohio
nutha
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421007
04/17/13 05:42 PM
04/17/13 05:42 PM
Canton, Ohio
Canton, Ohio
At least the stock bumper fits on the stock bumper mounts.
Re: 4-Speed Shifter Install Clearance Issues [Re: Rhinodart] #1421008
04/17/13 05:45 PM
04/17/13 05:45 PM
Canton, Ohio
Canton, Ohio
Ah so there is a notch! Is it on one side or both? Looks like one side...
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421009
04/17/13 05:45 PM
04/17/13 05:45 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Did you see my posts above?
JB Rhinehart, Realist
A-Body's RULE!
Re: 4-Speed Shifter Install Clearance Issues [Re: Rhinodart] #1421010
04/17/13 06:52 PM
04/17/13 06:52 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
That notch was on both my son's 67 Dart GT and my old 67 Dart GT (both original automatic cars). I believe is also on the 67 Barracudas. I'd have to get the GTS up in the air to see if the '68 had the notch.
Re: 4-Speed Shifter Install Clearance Issues [Re: Jim_Lusk] #1421011
04/17/13 08:07 PM
04/17/13 08:07 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
It is not on a few my automatic cars, but then again I have not had many auto's...
A-Body's RULE!
Re: 4-Speed Shifter Install Clearance Issues [Re: Rhinodart] #1421012
04/17/13 09:45 PM
04/17/13 09:45 PM
Canton, Ohio
Canton, Ohio
Okay, so these might be correct after all.
My car does not have the notch. Car is a GT originally with a 318/904.
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421013
04/18/13 12:38 AM
04/18/13 12:38 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Good picture of the notch:
Re: 4-Speed Shifter Install Clearance Issues [Re: Jim_Lusk] #1421014
04/18/13 06:25 AM
04/18/13 06:25 AM
Canton, Ohio
Canton, Ohio
Perfect, thanks Jim!
Re: 4-Speed Shifter Install Clearance Issues [Re: Jim_Lusk] #1421015
04/18/13 09:52 AM
04/18/13 09:52 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That looks like a homemade notch, mine look MUCH nicer than that, like they are stamped out!
A-Body's RULE!
Re: 4-Speed Shifter Install Clearance Issues [Re: Rhinodart] #1421016
04/18/13 10:38 AM
04/18/13 10:38 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Nope. That's factory. The picture may make it look more crude than it is. I cut the sheetmetal out and did not make the notch. I'll take a look at my Barracuda if I get the chance.
Re: 4-Speed Shifter Install Clearance Issues [Re: Jim_Lusk] #1421017
04/20/13 11:40 AM
04/20/13 11:40 AM
Canton, Ohio
Canton, Ohio
Alright. So backing up a bit... I was just under the car with some good light. I was not paying close attention the other day. There is a notch in the cross member. Feel a little silly that somehow I missed this.
So, I went back through all my pics and found the ones where I put the hump in.
I made more clearance with the grinder. It looks like it will work now, but things are still really close. What kind of clearance do you guys (with A-bodies!) have? There is very little clearance on the front of the cross member (where there is no notch).
The rods cannot be that far off, after all the shifter and rods were on the transmission when I got it.
I was also thinking some more, and the side cover and forks did change from when I mocked it up. I'll need to dig out the old side cover, but I don't see how the dimensions can be any different to affect the rod clearance.
Is it just these heavy duty rods? I am going to try to figure something out with the numbers on the rods. Try to see what I have for sure.
Some pics of the install. This was 10 years ago.
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421018
04/20/13 11:40 AM
04/20/13 11:40 AM
Canton, Ohio
Canton, Ohio
tunnel tacked.
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421019
04/20/13 09:46 PM
04/20/13 09:46 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The heavy duty rods do have clearance issues, everything is very tight in there. I usually mount an engine block with the trans and shifter then put place the hump on the floor before tacking it in if it was an automatic car being switched to a 4-speed, things tend to work better that way.
A-Body's RULE!
Re: 4-Speed Shifter Install Clearance Issues [Re: Rhinodart] #1421020
04/21/13 07:40 AM
04/21/13 07:40 AM
Canton, Ohio
Canton, Ohio
Rhino, that is exactly what I did when I put the hump in. Evidently I didn't connect the linkage when I mocked everything up.
I have another thread going. I am really just trying to figure out what I have. The shifter is stamped Competition Plus, but with the reverse lockout makes me thing it is a Super Shifter, unless the CP shifter could be had with reverse lockout?
The shifter is mounted in the stock location with the aluminum plate.
The rods and levers look nothing like the factory stuff. The lever slots are a different angle than the factory, and the rods are obviously thicker.
So, I'm confused as to how the levers need to be installed, as since they are different than factory they might not attach the same way.
Maybe I'll give Jamie and/or Brewer's a call tomorrow.
The saga continues.
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421021
04/21/13 10:53 AM
04/21/13 10:53 AM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
The Super Shifter did not have the reverse lockout lever. You had to push down on the shifter to get it in reverse. It was also spring loaded to the right while in neutral, great when speed shifting from 2-3, just shove it up & it went in. I remember the inline had a reverse lockout.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: 4-Speed Shifter Install Clearance Issues [Re: express] #1421022
04/21/13 11:10 AM
04/21/13 11:10 AM
Canton, Ohio
Canton, Ohio
Alright. Dunno man. Still trying to make sense out of this.
I might try to give Hurst a call. None of this stuff is available any more, so I'm not too confident that they will be able to help.
Re: 4-Speed Shifter Install Clearance Issues [Re: Crazy68Dart] #1421023
04/21/13 12:00 PM
04/21/13 12:00 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
It's a super shifter 3 with that red handle.
Re: 4-Speed Shifter Install Clearance Issues [Re: RobX4406] #1421024
04/21/13 02:17 PM
04/21/13 02:17 PM
Canton, Ohio
Canton, Ohio
Agree. Even though it says Competition Plus, from what I have found today it is a SS3.
The 2298 plate is for early As, so I am going to get the plate for 67-up and see if that helps my situation.
