Using old serpentine belts to lift with.......
#1420649
04/16/13 10:41 AM
04/16/13 10:41 AM
Posts: 12,814 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
I was at a buddies shop the other day and he was pulling an engine with a couple of old used serpentine belts. I was surprised they would hold that much. He had quite a few belts in different lengths hanging up on hooks and said he used them all the time.
I plan to pick up some at the local pick-a-part yard. They look handy as heck to lift stuff with.
Anyone else have any experience lifting with old serpentine belts?
Master, again and still
Re: Using old serpentine belts to lift with.......
[Re: DaveRS23]
#1420650
04/16/13 10:56 AM
04/16/13 10:56 AM
Posts: 6,621 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Good plan if you're looking for a bad experience IMHO. String will work too and is on about the same scale common sense wise. Your buddy is going to make the evening news someday. If you need to use that type of rigging, go to an industrial supply store and buy the proper nylon slings. They come in every size you can imagine. Kevin
[Re: Twostick]
#1420652
04/16/13 11:31 AM
04/16/13 11:31 AM
DaveRS23
Benton, IL.
So Kevin, have you ever actually tried this? Please read my question. I was asking for real world experiences, not opinions. Opinions without experience are simply guesses and often confuse the issue. Worse yet, Kevin, your opinion is condescending. Why? I simply asked for experiences. You have none on this subject. But you feel compelled to belittle a question with your opinion and comments. I would ask you to in the future to keep your lack of experience and lack of tact out of my posts. Your opinions are not more important than real experiences. Though you may think so. This shop has used belts for years now without problems. So there is one set of positive experiences. I will pick some old belts up the next few days. I have some engines laying around that I can use to see if they hold for me. I'll let you know.
[Re: Dcuda69]
#1420655
04/16/13 11:52 AM
04/16/13 11:52 AM
Challenger 1
Cincinnati, Ohio
I've used them to lift bare blocks around the shop...nice to be able to slide them down cylinders without fear of scratches,,etc. Got the idea from a buddy who does it in his machine shop also....no problems.
Yes that why I started using them , no scratches.
[Re: CR8CRSHR]
#1420660
04/16/13 02:38 PM
04/16/13 02:38 PM
Challenger 1
Cincinnati, Ohio
Completely stupid and risky idea. After all the rubber has degraded enough that the belt was swapped out from its original use and purpose. It therefore has no tinsel strength and has stretched out because of its original usage. It is just a matter of time before complete failure and either serious or catastrophic injury. Just a bunch of Clowns and Knuckleheads would attempt to do something like this. And I do not care if you can post pics of them being used in such a fashion. It is still freakin...
Come on! tell us how you really feel, out with it!
What about new one's? think then it would be alright?
[Re: DaveRS23]
#1420665
04/16/13 05:08 PM
04/16/13 05:08 PM
Posts: 3,419 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
It sounds like you have already kind of made up your mind the answer that you want to hear, so why not just go ahead and use them?
Nylon rigging slings don't cost much, come in many sizes, and are actually designed and intended to hoist heavy, irregular sized objects. Serpentine belts aren't. Why take a chance for a few dollars?
A lot of people work under cars on hydraulic jacks and don't die--that doesn't make it a good idea.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: ns1aar]
#1420666
04/16/13 05:08 PM
04/16/13 05:08 PM
Challenger 1
Cincinnati, Ohio
I'm not doubting that they are strong enough to lift a motor, especially 2 per motor.
I've always used a piece of chain with bolt on ends and a lifting loop that can't slip on chain, on the lifting hook when I can't use a carb lifting plate.
I've used chains and had the bolt break. Was it safer? Can't plan for everything
I use flat pieces of steel with a hole in it on the end of my lifting chain they get bolted on to what ever I'm lifting, bolted tight, torqued tight. Your bolt will never break if you use them like that. Never do I stick a bolt in a head or block and leave it stick out because it put's tons of stress on the part your lifting and the bolt. Torqued tight with flat piece of steel to whatever your lifting will never let you down.
Can you believe I don't have pictures ready?
