Re: anyone here run a 4l80e?
[Re: an8sec70cuda]
#1418628
04/16/13 11:17 AM
04/16/13 11:17 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Ray, I thought about it more after we talked the other day...having OD would be really nice, but there's no way it's worth 3 tenths to me. Not even 2 tenths. I'd go w/ the 727 every time if I knew it was even 2 tenths quicker. Especially considering the cost. I worked long and hard to get my car to run where I'm happy w/ it...it wasn't built for fuel mileage, lol.
that's why I called you. You know whats really important
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: tsanchez]
#1418630
04/16/13 02:07 PM
04/16/13 02:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
My buddy loves his 700r4 but says if he did it again it would be a 200r4.. he has the OD and the lock up behind his 460 BB ford in a 3900# truck and turns 1.52 60'... he runs a 4000 stall conv with a cooler and fan but it seldom sees 200* even in the heavy city traffic
[Re: MR_P_BODY]
#1418631
04/16/13 03:32 PM
04/16/13 03:32 PM
sixpackgut
Charleston
If I had $5k falling out of my pockets I would probably do the electronically shifted 4l80e, but I don't so it all about cost with me. how much does it cost to put A/C in a car
[Re: sixpackgut]
#1418632
04/16/13 06:28 PM
04/16/13 06:28 PM
Quicktree
about $1300 for a complete kit
[Re: sixpackgut]
#1418633
04/16/13 09:32 PM
04/16/13 09:32 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Why not just go with a Gear Vendors.????
Chris..
[Re: Chris'sBarracuda]
#1418634
04/16/13 11:22 PM
04/16/13 11:22 PM
sixpackgut
Charleston
Chris..
i may, just wish the GV was .70-.75.
[Re: sixpackgut]
#1418635
04/16/13 11:34 PM
04/16/13 11:34 PM
Chris'sBarracuda
Arizona
Chris..
We had a Motorhome with a TH400 and a GV.. That was a cool set up and very durable..
You could shift it like a 6 speed..
You could go with a TH400 and a GV..
Better converter choices too..
Chris..
[Re: Performance Only]
#1418637
04/17/13 11:41 AM
04/17/13 11:41 AM
sixpackgut
Charleston
Chris..
For what your doing i'd still take the 4L80E over a gear vendors. Call me and we'll talk about it. I've done both. I don't believe the .2-.3 loss in E.T. from what i've seen. I think sometimes people mismatch their tire and gears when they do the changeover. As far as A/C, I can tell you the Vintage air unit is superior to the classic auto air system. I've installed both and the quality of the components is far different between the two. We've had to do numerous warranty repairs on the latter but not a single one on the Vintage units.
Can I call you to borrow money? I know you got it
[Re: sixpackgut]
#1418638
04/17/13 11:47 AM
04/17/13 11:47 AM
MR_P_BODY
I was gonna go with a 727 and a GV OD but I couldnt do $3000 for just the OD.. so I had to compromise and went with what I did.... on the air... I put a Vintage unit in my 38 ply... nice stuff
[Re: MR_P_BODY]
#1418639
09/29/14 08:05 PM
09/29/14 08:05 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
BTT
So, if a guy wanted to run one behind, say a Gen3 Hemi, what adapter would he be looking for?
SBM to GM trans or is there a specific one for a Gen3 to 4L80E?
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: neilaf]
#1418641
03/19/15 11:00 PM
03/19/15 11:00 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I've known Lonnie (Extreme Automatics) for a long time he a great guy and builds great units. We were talking because I was trying to decide which trans to put in my cuda behind a 588 kb hemi I was thinking 727 and gear vendors but he said and it makes sense if you run a high stall non lock up converter when the gear vendors goes into overdrive and the rpm drops the converter never couples and slips more so it does not work for what I was looking for so I'm going with a 4l80e plus I like the idea electronic shifting hard to manually shift consistently and not over rev it once you start going fast and an air shifter is not practical for the street.
the load factor isn't there to cause the "stall" condidtion like launching off the line. Have a 727 2800 stall converter in my Fathers 90 ramcharger with the factory non-lockup 518 trans. He cruises it every saturday on the interstate for an hour and the transmission fluid temp doesn't move from normal temp the whole time. We live in florida also and has his A/C running too.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: 65 Hemi]
#1418643
03/19/15 11:36 PM
03/19/15 11:36 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Don't wanna see another 4L60 OR 4L80 tranny the rest of my life...I retired from that assembly plant...We had three to four lines running at 175 to 190 transmissions per hour, per line..!! But quality was outstanding...One failure per 6o thousand units built..JD Powers listed our plant as having an exceptional rating...618 parts per unit.!..Fully assembled they would pressurize them under water for any leaks with torque converters installed...Try working THAT job..Dropping 175/190 torque converters on the assembled trannies per hour..8 hours of that and I guarantee a good nights sleep.!!
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: neilaf]
#1418645
03/20/15 08:34 AM
03/20/15 08:34 AM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
Forgive my hijack, but if the GV causes the converter to not couple, what would be the difference in any of the other OD trans in this discussion without lockup? It has already come out that there is not enough clutch in a locking converter to hold a high HP engine. Just wondering as I have been waiting to drive my 540ci HEMI with 3,0000 stall converter and GV set up.
[Re: dogdays]
#1418647
03/20/15 03:06 PM
03/20/15 03:06 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
BUT............................ At 60mph you're using about 35 horsepower and no matter what engine is on the front, the torque converter clutch only has to transmit the torque to make that horsepower at the cruise rpm.
That assessment is completely correct at steady-state. And your trans could be a grenade with the pin pulled. For many things in life it's not about what's going on -- but rather what happens next.
When you open the throttle the engine torque will increase, and you’ll need to have enough LU pressure to keep that clutch clamped. And in OD the vehicle load/resistance is actually higher than in lower gears, so the normal human instinct will be to push more throttle.
how the OEMs do it An OEM designed system will know what that new torque is (a calculation from the engine ECU, also validated by lots of testing) and adjust pressure or drop LU and/or OD. Things are designed and calibrated from clutch area, coeff of friction, pressure, temperature, etc, + a safety factor. All of this is highly reviewed/calculated and then validated by *lots* of testing. Wanna have fun? Ask your trans expert the coefficient of friction of OEM paper vs the Red friction, and see what his response is.
but I’m aftermarket? But in an aftermarket application you might only have a TPS signal (with EFI, or if a TPS has been piggybacked onto a carb for such a purpose). You’d need to make sure your module will put enough pressure on the LU clutch when that happens. Even then you wouldn’t know how much pressure would be required, so maybe you’d just make it the max for anything above say 50% throttle? But how would you know if 50% was the right setting, or if max pressure was enough? Who wants to toast their LU clutch to validate their assumptions?
Sheesh, dude, I’ll just do this then. So let’s say you play it safe and go with 30% for max pressure.
Well, another thing is : If your rpm (trans input rpm) is low enough due to being in OD the pump flow could be low (via pump sizing and/or electronically-controlled pressure bleedoff). Modern transmissions keep pump flow just above the minimum for any given condition, as pumping oil costs hp and fuel, and a transmission is known to be a good place to minimize fuel usage. So even if you tell your aftermarket controller to command max pressure, you might not get it -- and you wouldn’t know, either. Oh, you might know if you got slippage, and it would be easy to misdiagnose the reason and put an incorrect/inadequate fix in place, thinking you fixed it, and maybe get a worse slip next time (or in a different clutch).
Also, just because you can easily change behavior via solenoids, you still have the mechanical characteristics of valve bores and valves/springs, some of which balance/feed off each other. For any pressure you increase for one clutch, you may risk decreasing pressure to a different one, or altering cooler flow (which is also your lube circuit). I would think this would be an area where many transmission modifiers would get themselves out on a limb and have warranty issues until they figured the limits of the hardware.
If you’re still reading all this I spent many an hour looking at real-time data traces of transmission testing, as controlled by an ECU or a module to manually trigger solenoids, and have seen more than a few puffs of smoke come out of a dipstick tube for a variety of reasons. I had the luxury of doing an autopsy afterward, to look at data (secret ECU data and also instrumented transmission data) that very few hotrodders will have access to (or interest in). I also had to be trained in how to interpret that data, as it was easy to incorrectly identify ‘the smoking gun’. Specific to this discussion - I’ve seen pressures be commanded yet not be obtained -- and not always for the same reason.
So back to the grenade – You can program your controller with the best intentions, and pussyfoot when in OD/LU, but wouldn’t you always wonder if you pushed the throttle too hard at highway speed if you’d hit the limit?
As hotrodders we're conditioned that things break from being pushed too hard, but IMHO an electronically-controlled transmission can be disabled under simple driving conditions if it's modified incorrectly.
what I'd do: If I had a high-torque engine and LU, I'd get a converter with the best friction material I could afford, and maybe boost LU pressure a little. Then I'd drive around cautiously and make sure my module drops LU and OD very readily with increase in throttle and drops them in the same pattern as the OEM did (simultaneously, or one before the other) and then I'd tweak it to until annnoyng. Then I'd drive some more and raise the TPS threshold to where I could drive it without cycling things too much with my foot. then maybe raise the LU pressure a few percent. And then nobody would drive that car but me unless it was an emergency...
Unless you're *really* intimate with a particular transmission, follow the factory footsteps as much as possible.
