Anyone sell a stock-style fuel pick-up with 1/2" line? #1418513
04/12/13 12:08 AM
04/12/13 12:08 AM
Ohio
Cincylance Offline OP
Ohio
I am in the process of converting back to a stock tank set-up. I have everything I need except a 1/2" stock-style fuel pick-up. I have a new 3/8" unit, but since the entire line is a 1/2", I'd like to have a 1/2" pick-up. Is there anyone that can convert my new, never used 3/8" pick-up over to 1/2"
Thanks,
Cincylance
(Moparts member since 1998)
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: Cincylance] #1418514
04/12/13 12:14 AM
04/12/13 12:14 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: pittsburghracer] #1418515
04/12/13 12:16 AM
04/12/13 12:16 AM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: pittsburghracer] #1418516
04/12/13 12:21 AM
04/12/13 12:21 AM
Ohio
Ohio
http://chucker54.stores.yahoo.net/abody3.html
Thanks for the link, but I must be on crack...I can't find my model.
Looking for a 64 b-body 1/2" fuel pickup in the b-body list:
http://chucker54.stores.yahoo.net/bbody3.html
Is it here, but I'm not seeing it?
Cincylance
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: Cincylance] #1418517
04/12/13 12:31 AM
04/12/13 12:31 AM
PA.
"Little"John
"Little"John
PA.
Not real sure I just jumped on Mancini's site to check and I saw those ones. It may be worth a call. I had a Friend that made his own years ago am he said it wasn't a real hard job.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: Cincylance] #1418518
04/12/13 01:01 AM
04/12/13 01:01 AM
I have added another pick up besides the stock one(with a sock ) and then fed both into a Y fitting to the 1/2 inch line I have also had a 1/2 inch return lined installed and welded into a stock pick up and then fed the pump from the bottom in a custom made sump
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: Cab_Burge] #1418519
04/12/13 02:28 AM
04/12/13 02:28 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
http://www.vansauto.com/sending2.html
Bottom of the page.
I just ordered some A body stuff, it was here in 2 days.
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: slantzilla] #1418520
04/12/13 02:22 PM
04/12/13 02:22 PM
dogdays Offline
dogdays  Offline
The neat thing about fluids is that they can speed up to go through a smaller area. The less than one foot of 3/8 will cause much less than 1/10psi increased pressure drop in the system.
Quick calculation, some numbers are guesses so don't shoot me:
800 hp engine running at 0.50 BSFC means it will burn 400 lb of fuel in an hour. Assume 7 lb/gallon fuel you get 400 / 7 = 57.2 gallons per hour or 1 gpm. Assume tubing has 1/16 wall, so the 1/2" tubing is 3/8"ID and the 3/8" tubing is 1/4" ID.
Calculating areas the 1/2" line is 0.1104 square inches and the 3/8" line is 0.0491 square inches.
A gallon is 231 cubic inches so to calculate velocity we divide flow by area: 231 / 0.1104 = 2092.4 inches per minute.
231 / .0491 = 4704.7 inches per minute.
Sounds bad, doesn't it? But we have to change it into something more standard like feet per second, so:
2092.4 /60 = 34.87 inches per second
4704.7 / 60 = 78.41 inches per second
Convert both to feet per second:
34.87 / 12 = 2.91 ft/sec
78.41 / 12 = 6.53 ft/sec.
My rule of thumb for a properly designed piping system is 7 ft/sec.
So let's assume 21 feet of 1/2" tubing and another system with 20 feet of 1/2" tubing and 1 foot of 3/8" tubing.
At this point I jump the tracks because I don't want to have to calculate friction factor and viscosity effects of gasoline, so I am switching to the published data for water in Type K copper tubing.
We previously figured out 1 GPM is close.
For 21 feet of 1/2" tubing pressure loss is 2.87 x 21 / 231 = 0.26psi pressure loss from end to end at the 1GPM flow rate.
For 20 + 1 it is [(2.87 x 20) + (1 x 10.32)] / 231 = 0.29 psi loss from end to end.
So you are going to all that bother for 0.03psi difference? I hope it's worth it to you, because from a practical standpoint it makes no difference whatsoever.
R.
Note to "those who were paying attention"
The 231 cubic inch per gallon is correct, but not related to the 231 I used in the last two calculations. In those calculations I used head loss for 100 feet of tubing, so had to divide by 100 to get head loss per foot. Then having to change from units of feet of head to psi, 2.31 feet of head equals 1 psi. So because I was dividing by both the 100 and the 2.31, I multiplied them first to avoid an even messier-looking equation.
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: dogdays] #1418521
04/12/13 04:28 PM
04/12/13 04:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You have to remember 1 thing here... this is on the
suction side so in reality atmospheric pressure is
pushing the fuel to the pump... you always want bigger
on the inlet side.... you guys do the same thing for
the oil pick up in the oil pan but most dont think
of this in the same way.... it IS the same
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: MR_P_BODY] #1418522
04/12/13 07:48 PM
04/12/13 07:48 PM
dogdays Offline
dogdays  Offline
HA! I know it's on the suction side of the pump but it STILL doesn't make any difference. I have been designing pumping systems for 20+ years but no, I don't know anything!
Do what you want if it makes you feel better. No problem for me. Facts are facts, though, and the fact is that it'll take about 0.03psi extra to push that amount of fuel through one foot of 3/8" tubing. Even at 10,000 feet elevation you're still okay.
R.
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: dogdays] #1418523
04/12/13 07:52 PM
04/12/13 07:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
R.
Ok... your the pro... I only did it for the fuel lab
at Chrysler 35 years... but thats fine I dont know sh1t
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: MR_P_BODY] #1418524
04/13/13 12:51 AM
04/13/13 12:51 AM
Theory is one thing, engineers are another thing and reality is what it is Test,test, and then test some more to back up theory, if testing doesn't back up the theory change it(the theory)
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: Cab_Burge] #1418525
04/13/13 03:20 AM
04/13/13 03:20 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I made my own fuel pickup from 5/16" to 3/8" on my '64 Polara. It would be just as easy to do it in 1/2" line, of course the sock at the end would have to be made too, but that is easy enough or do without. I just took the original piece out and formed a line to match the curve in the larger tubing, swedged it to fit and silver-soldered it in place. The heating ruined the level sending unit, but I discovered that one for a '67 Mustang fit the same, was accurate and they are cheap ($15.00 @ Bel-Kirk Mustang). I had to make a ground strap to bridge the rubber connecter of wire. Probably $30.00 in materials and some time. Easy to do
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: Polarapete] #1418526
04/13/13 04:50 AM
04/13/13 04:50 AM
sweden
sshemi Offline
sshemi  Offline
sweden
So maybe 3/8 is fine now, but that wont leave him much room to grow.
Why would you want to speed up the fuel????
To cause cavitation?
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: sshemi] #1418527
04/13/13 08:30 AM
04/13/13 08:30 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
What oil pan are you using? Race or street engine?
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: slantzilla] #1418528
04/14/13 12:25 PM
04/14/13 12:25 PM
Ohio
Ohio
Bottom of the page.
Thanks for the tip, I just ordered a 1/2" pick-up from Vans. Thanks to others for your equations and advice. Even if the difference is neglible, it seems patched-together to have a 3/8" to 1/2" line.
Cincylance
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: cgall] #1418529
04/14/13 12:28 PM
04/14/13 12:28 PM
Ohio
Ohio
This is a street engine making 625 horse. Oil pan is a Milodon deep sump street/strip version. Why does that matter relevant to the fuel pick-up?
Cincylance
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: Cincylance] #1418530
04/16/13 12:43 AM
04/16/13 12:43 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Nice Fury!
I made a 1/2" pick-up for my Savoy a few years ago. Used 1/2" thin wall stainless steel(EBAY) and bent a curve with a handheld bender with fine ss mesh for the sock.
Re: Anyone sell a stock-style fuel pick-up with 1/2" line? [Re: 52savoy] #1418531
04/16/13 07:02 AM
04/16/13 07:02 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Ebay has 3/8 and 1/2" fuel pickups.
