Use the rubber rings on caliper? #1418227
04/11/13 11:52 AM
04/11/13 11:52 AM
K
kielbasa Offline OP
kielbasa  Offline OP
K
Hi guys, installing new calipers (sliders).....my question is am I supposed to use the o-rings (square actually) - looks like they go between the caliper adapter and caliper? Are they there for noise suppression?
Just wondering if I have to install, or do most guys just pitch them?
Thanks.
Re: Use the rubber rings on caliper? [Re: kielbasa] #1418228
04/11/13 12:05 PM
04/11/13 12:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Toss them.If they are installed they will probaly last a month if you are lucky.Rocky
Chrysler Firepower
Re: Use the rubber rings on caliper? [Re: therocks] #1418229
04/11/13 12:59 PM
04/11/13 12:59 PM
X2 on tossing em. I would wire brush the grooves clean & bend the 2 L tabs on the one pad so it fits real tight on the caliper and the other pad has some lateral side play (file the ends if needed) so its loose
