Tranny problems with 5.9 Dakota #141808
10/26/08 06:23 PM
10/26/08 06:23 PM
Anonymous OP
Anonymous OP
I started my truck up for the first time in a couple of weeks today. It was parked because the tranny was all messed up. It was running cold and went right into gear, both reverse and drive. I moved my other car to take it down the road and when I got out it was making a grinding noise from the tranny. I very slowly went into drive and did not move well at all, like it was slipping. As it got warmer, it eventually didn't move at all. Anyone know what could be up with it?
Re: Tranny problems with 5.9 Dakota #141809
10/26/08 06:30 PM
10/26/08 06:30 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
the 46re is famous for being a weak tranny. It could be time for a rebuild? When was the last time you did a band adjustment? Checked your trans fluid? If so what color was it? did is smell burnt?
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: Tranny problems with 5.9 Dakota [Re: blk00rt] #141810
10/26/08 07:03 PM
10/26/08 07:03 PM
Anonymous OP
Anonymous OP
I think its a 46RH tranny. Out of a 94 Dodge Ram. Its was recently flushed because it got full of water. The fliud does not smell burnt and is red. If there is any more water in it, could that cause this to happen?
Re: Tranny problems with 5.9 Dakota #141811
10/27/08 05:34 PM
10/27/08 05:34 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Water could of been in it long enough to ruin the clutches.
