Chrysler Engineering Drawings with 0 inch reference
#1417951
04/10/13 11:41 PM
04/10/13 11:41 PM
Posts: 17,514 Las Vegas, NV
6bblgt
Las Vegas, NV
On the various Engineering Drawings that are out there with reference to decal/emblem placement. All placements are dimensioned from a 0 inch reference line. I'll "assume" left to right is easy - center of car, but where is this line front-to-back & top-to-bottom?
Re: Chrysler Engineering Drawings with 0 inch reference
[Re: 6bblgt]
#1417952
04/11/13 12:16 AM
04/11/13 12:16 AM
Posts: 18,406 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Where do you see this O reference in the posted drawing? I see it following the body/ character line in this drawing. Not quite sure what you are asking for??.
[Re: NITROUSN]
#1417954
04/11/13 12:51 AM
04/11/13 12:51 AM
6bblgt
Las Vegas, NV
Correct, there is no ZERO INCH line on the drawing - that's the question: Where is it? In the Y view: notations are 13.93" & 15" (positive) top-to-bottom from where? and 130" & 133.82" (positive) front-to-back from where? In the Z view: notations are 13.18" & 15" (positive) top-to-bottom from where? and -50" & -50.34" (negative) front-to-back from where?
[Re: Alaskan_TA]
#1417955
04/11/13 12:55 AM
04/11/13 12:55 AM
6bblgt
Las Vegas, NV
The zero line - draw a straight line axle center to axle center - front to back.
Are you sure? Wouldn't that ZERO-LINE change based on factory ride height & rear springs? (an AAR's 0-line would be different from a 383 'Cuda)
[Re: 6bblgt]
#1417956
04/11/13 12:56 AM
04/11/13 12:56 AM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
See above comment.
Front & back on the V9_ Challenger stripe drawings came from the front of the cowl top. I have not checked any other original cars against the drawings, but the one I did check was spot on.
[Re: 6bblgt]
#1417958
04/12/13 07:00 AM
04/12/13 07:00 AM
Posts: 974 www.mmcdetroit.com
MMC Detroit
www.mmcdetroit.com
The wheel center line is usually the most convenient point to make the master horizontal datum (0) line. However,sometimes the bottom of the chassis (frame) is also used.
In general there is a vert and horz datum line. This is not always in the same location from car to car. It is want ever point is established a points of reference for a particulate model. It could be the fire wall or front when centers. The remaining grid lines are located relative to those two "zero" lines. When I get home this weekend I will see what I can find.
Generally some on this information can be found in the original master collision manuals.
MMC/ ICCA Detroit.
The Motor City or where ever there is Mopars
