340 exhaust worth the extra $$$$? #141781
10/26/08 06:03 PM
10/26/08 06:03 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
Everywhere I look, people want big dollars for 1968-70 340 exhaust manifolds. I see great set of headers that would work great and usually a third of the cost, but people would rather spend their dough on those manifolds.
My question is, if there was a hp diffrence in 340, 318 and 1971-later 340 manifolds, what is that diffrence and is it practical hp number to support a decently build small block?
Re: 340 exhaust worth the extra $$$$? [Re: migsBIG] #141782
10/26/08 06:32 PM
10/26/08 06:32 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
It all depends on the build and if it were built around using manifolds. The difference from the 318 to the 71 340 manifolds may not be big, The difference between the 71 340 and earlier 340 manifolds maybe even less but I bet the difference between the 318 manifolds and headers will be a good 25hp on a 400hp motor.
Re: 340 exhaust worth the extra $$$$? [Re: AdamR] #141783
10/26/08 06:46 PM
10/26/08 06:46 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the reason I went with the 340 hp mani's on my convertible was ease of installation for an exhaust system...stock mani's gets u a nice high performance bolt on system...headers/exhaust system will have to be done by a shop...i compared the difference..time/money and it paid for me to by the mani's and install the whole thing myself... but that's up to you
Re: 340 exhaust worth the extra $$$$? [Re: migsBIG] #141784
10/26/08 07:19 PM
10/26/08 07:19 PM
Worcester, Mass
68goldfish Offline
68goldfish  Offline
Worcester, Mass
Yes, spend the money. One thing people tend to forget is the massive amount of heat that headers give off for a small gain in HP. Cast iron will help control noise and heat under the hood.The 68-70 cast iron flow close to what a header will give.
Re: 340 exhaust worth the extra $$$$? [Re: 68goldfish] #141785
10/26/08 07:50 PM
10/26/08 07:50 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Make no mistake though the 318 manifolds are no where near the 340 even the later 340 manifolds will put the 318 manifolds to shame. No comparison. Just looking at them should show you the difference.
Re: 340 exhaust worth the extra $$$$? [Re: MoparforLife] #141786
10/27/08 09:22 PM
10/27/08 09:22 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
This should help.
on a 300hp 360 magnum there was 4hp and 6ftlbs of torque difference between the 318 manifolds and the early 340 manifolds.
There was 11hp and 16ftlbs difference between the 340 manifolds and a set of TTIs.
Thats with a very mild cam that I believe has a wide lsa.
The more power the motor makes the igger the difference you will see between the hp manifolds and headers.
That said Im still considering running manifolds on my next motor.
Re: 340 exhaust worth the extra $$$$? [Re: 68goldfish] #141787
10/27/08 11:14 PM
10/27/08 11:14 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Wrap the headers and you will take care of the heat.
Re: 340 exhaust worth the extra $$$$? [Re: Dart 340] #141788
10/28/08 01:16 AM
10/28/08 01:16 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Bolt on some JY Magnum manifolds
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 340 exhaust worth the extra $$$$? [Re: Dart 340] #141789
10/28/08 07:44 AM
10/28/08 07:44 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
The wrap will hold moisture and rot the pipes though. Having the headers coated in and out is a better idea.
Re: 340 exhaust worth the extra $$$$? [Re: AdamR] #141790
10/28/08 07:50 AM
10/28/08 07:50 AM
the higher the hp potential of the motor, the bigger the gains you'll see going to the headers
Re: 340 exhaust worth the extra $$$$? [Re: AdamR] #141791
10/28/08 09:59 AM
10/28/08 09:59 AM
Get-X Offline
Get-X  Offline
This should help.
Which 318 manifolds? The good magnums or a set off of a 72 318 2bbl motor? The early magnum manifolds are very good and are comparable to the early 340s where as the non-magnum 318 manifolds are no where close.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: 340 exhaust worth the extra $$$$? [Re: Get-X] #141792
10/28/08 11:36 AM
10/28/08 11:36 AM
This should help.
They were 1969 318 manifolds. They also tested 1977 360 manifolds.
http://www.moparmusclemagazine.com/techarticles/155_0307_mopar_crate_engine_exhaust/photo_17.html
The difference between the 69 318 manifolds and the good 340 manifolds was only 4 hp at peak, but the 340 manifolds were 7 hp stronger at 4000 rpm, 5 hp stronger at 5000, and 8 hp stronger at 5400 - despite the motor being almost 1000 rpms above its 4500 rpm power peak.
Draw your own conclusions about how well the old 318 manifolds would work on a higher revving engine . . . .
(That said, the 77 360 manifolds looked pretty good.)
Re: 340 exhaust worth the extra $$$$? #141793
10/28/08 11:42 AM
10/28/08 11:42 AM
Upper Midwest
Upper Midwest
This should help.
Better check out your dyno if you got those small port, small log manifold to flow up that close to the early 340 manifolds because they sure don't show it in the real world. Another reason I don't put much faith in dyno testing.
Re: 340 exhaust worth the extra $$$$? [Re: MoparforLife] #141794
10/28/08 11:54 AM
10/28/08 11:54 AM
Hey - it ain't my dyno, and I've posted a number of times that I don't have much faith in this particular test, as I've said just about every time it has been cited (and it's come up again and again).
Just pointing out factors to consider even if you accept the validity of one test of one motor.
Re: 340 exhaust worth the extra $$$$? #141795
10/28/08 12:02 PM
10/28/08 12:02 PM
I knew of a SB abody that was in the 12's with them(68-70 HP manifolds). They are pricey. visually comparing them to the 318 logs they gotta be quite a bit better .
Re: 340 exhaust worth the extra $$$$? [Re: RapidRobert] #141796
10/28/08 03:12 PM
10/28/08 03:12 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I'd be willing to bet someone else's money that the pinch on the DS 340 manifold is smaller than the outlet on the 318 turd manifolds, so regardless of how nice they look, they're really no better than any other log. I wish MM, MA, or some other magazine would run a drag test as well, and maybe plug in a WBO2 sensor to get some additional data. Personally, I think the MM test is a very good indicator of the way things work, regardless of whether it's EXACTLY right or not.
A concern I have is how the various manifolds affected the mixture on the test engine. I don't know if the mix was optimized for each change, which is how anybody really tuning a combo would do things. How many times have we heard about folks bolting on headers and slowing down? Most likely it's due to the new better flowing combo running leaner than the old restrictive combo.
It's also a good point to see the whole power curve, not just peak numbers. A combo that puts more power under the curve will be faster than one with a higher peak but less under the curve.
Clair
Re: 340 exhaust worth the extra $$$$? [Re: Clair_Davis] #141797
10/28/08 03:53 PM
10/28/08 03:53 PM
Upper Midwest
Upper Midwest
Clair
Evidently never rally looked at or compared them in a real world application. Are they worth it at teh price collectors are willing to pay for them? IMO - no not when you can get a new style magnum manifold that will perform just short of as well for a lot less $$$.
Re: 340 exhaust worth the extra $$$$? [Re: MoparforLife] #141798
10/28/08 04:30 PM
10/28/08 04:30 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I had a set of 340 71 style on the 71 challenger my wife drove day in day out no parking ots worries or anything and the car ran fine. but i think that the stroker will get some hookers that i already have.
I wonder how the 73 340 ones i have compair to the 71 ones i have? the older ones are shaped differant and have a flat hook up where the pipes go on.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: 340 exhaust worth the extra $$$$? [Re: RapidRobert] #141799
10/28/08 08:54 PM
10/28/08 08:54 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Theres guys running the FAST series in the 11s with the 71 style 340 manifolds (center dump passenger side)that doesnt mean they wouldnt pick up a bunch of power switching to headers.
Take a look at a set of 71 340 manifolds and then a set of early 318 manifolds.
Re: 340 exhaust worth the extra $$$$? [Re: AdamR] #141800
10/28/08 09:13 PM
10/28/08 09:13 PM
I was going to run a pass one on both sides(band saw it just out from the head ports,reverse it & reweld it) & do what I need to do to make the steering shaft clear. Might be an easier/softer way to get-er-done but I get anal about these things(on occaision)
