Re: Water/Meth Injection
[Re: 6bblFLASH]
#1411549
04/07/13 08:13 AM
04/07/13 08:13 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I have zero experience with water meth injection. But, something comes to mind. I have a 13.2:1 compression engine that runs fine on 112 octane. With water meth would this engine survive on pump gas. What is the deciding factor as to when the injection turns on. With boost I guess it is just a switch but, what would make the determination on a NA engine?
Leon
[Re: Leon441]
#1411550
04/07/13 12:08 PM
04/07/13 12:08 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Leon
runs off vacuum, when the vacuum drops to zeroish (engine under load) the system starts fogging. So say you are at the track, you do you brun out pull up to the the line, turn the system on, stage and nail it. While you are at WOT and enigne is under load it will spray, when you let off it shuts off. It uses a relay. The Snow Perf Stage I kit has everything you need.
[Re: Clanton]
#1411552
04/07/13 01:33 PM
04/07/13 01:33 PM
Leon441
Lynchburg, VA
So I could basically wire it up like a nitrous activation with the exception of the WOT switch. Just use a vacuum switch.
The big thing I am looking at is street driving. I need to fog whenever the engine is under load. A simple 1 gallon jug is not going to cut it. I also need to look at multiple stages to cover different amounts of load.
Again similar to nitrous just instead of timers it would be MAP switches.
Am I still clueless? Probably
Leon
[Re: Leon441]
#1411554
04/07/13 02:24 PM
04/07/13 02:24 PM
Mr.Yuck
Brookeville, Md
Leon
Mine is run thru a NOS 'noid but that is not needed. It's more of a safety feture to keep the juice from "back-filling" via suction. 1 gallon will last you a loooooong time. I have a 3qt tank and can race all day w/o filling it up. That's including the drive there and back. (22miles each way) If you feel like you need more that one stage. Snow has many kits available.
