Page 3 of 4 1 2 3 4
Re: Water/Meth Injection [Re: racealittle] #1411529
04/02/13 08:11 PM
04/02/13 08:11 PM
I was just looking at the snow unit, $400 plus.
Re: Water/Meth Injection [Re: ] #1411530
04/02/13 10:41 PM
04/02/13 10:41 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
All I can say is watch ebay, I got a new snow tow max system for a little over 300.00
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Water/Meth Injection [Re: megajoltman] #1411531
04/03/13 02:40 AM
04/03/13 02:40 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Mainbody:
This area was hollow so I epoxied it solid. I may endup boring out the base and threading the nozzle directly into the mainbody IF it blows out the gasket
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Water/Meth Injection [Re: 6bblFLASH] #1411532
04/03/13 02:45 AM
04/03/13 02:45 AM
N.E. Ohio
N.E. Ohio
Base is drilled and tapped for nozzle.
Fitting just for example
Re: Water/Meth Injection [Re: 6bblFLASH] #1411533
04/03/13 02:48 AM
04/03/13 02:48 AM
N.E. Ohio
N.E. Ohio
Passage in side of mainbody intersects with passage out the bottom,also threaded to plumb water/meth to the nozzle.
Re: Water/Meth Injection [Re: 6bblFLASH] #1411534
04/03/13 02:49 AM
04/03/13 02:49 AM
N.E. Ohio
N.E. Ohio
#2
Re: Water/Meth Injection [Re: 6bblFLASH] #1411535
04/03/13 02:53 AM
04/03/13 02:53 AM
N.E. Ohio
N.E. Ohio
Its just that simple. Took me all of an hour with a hand drill.
Laided awake for HOURS coming up with the idea.
I have`nt come up with any reasons why it won`t work ........
Thoughts?
Re: Water/Meth Injection [Re: 6bblFLASH] #1411536
04/03/13 03:11 AM
04/03/13 03:11 AM
N.E. Ohio
N.E. Ohio
#3
Re: Water/Meth Injection [Re: 6bblFLASH] #1411537
04/03/13 06:20 PM
04/03/13 06:20 PM
N.E. Ohio
N.E. Ohio
4# This what I`m trying to avoid.
Re: Water/Meth Injection [Re: 6bblFLASH] #1411538
04/03/13 06:48 PM
04/03/13 06:48 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
what kind of spray nozzle are you going to use?
Re: Water/Meth Injection [Re: Clanton] #1411539
04/04/13 12:19 AM
04/04/13 12:19 AM
Amherst,NY
challengermike Offline
Amherst,NY
The only thing I question about this is it going to cause it to puddle in the blower. Not much room until it hits the rotors and will it make it to all the cylinders not just the middle ones?
Re: Water/Meth Injection [Re: challengermike] #1411540
04/04/13 01:37 AM
04/04/13 01:37 AM
N.E. Ohio
N.E. Ohio
Possible.but it can't puddle any worse than shooting against the wall of a 3in tube like everyone else does.
No I'm not worried about distribution. Where things go inside there is anyone s. guess.I guess I could use a"T" and run two really small nozzles spraying outward. With 2 rotors spinning 10, 000rpm I doubt it will matter.
Getting a nozzle from McMaster.625ml and a couple other sizes to play with. Their nozzle is very short and will bearly extend past bottom of the carb. giving it the max distance to fan out
Re: Water/Meth Injection [Re: 6bblFLASH] #1411541
04/04/13 01:59 AM
04/04/13 01:59 AM
Cab_Burge Online work
Cab_Burge  Online Work
Something is better than nothing Now comes the hard part, what size, mixture ratio and pressure works the best Good luck, BTW, you need two carbs and bigger blower
Re: Water/Meth Injection [Re: Cab_Burge] #1411542
04/04/13 02:24 AM
04/04/13 02:24 AM
N.E. Ohio
N.E. Ohio
I have 3 carbs on my other car. You send the blower and I promise to use it.
Re: Water/Meth Injection [Re: 6bblFLASH] #1411543
04/04/13 02:25 AM
04/04/13 02:25 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Is that a KB hyper piston?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Water/Meth Injection [Re: Von] #1411544
04/04/13 02:30 AM
04/04/13 02:30 AM
N.E. Ohio
N.E. Ohio
Yes it is. In my 383 lasted about 20seconds.
Too much timing too much compression too much fun. BOOM
Re: Water/Meth Injection [Re: 6bblFLASH] #1411545
04/04/13 09:16 AM
04/04/13 09:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I burned 2 #3's up on my old S/C'd 440. cast speed pros. My fault both times for not turning on the electric pump. Once on a joy ride and once at the 1000 foot mark. Was well on the way to an 11 second pass and the car shimmied and cut off. Still went 12.19. I blame the Mustang in front of me for spitting an axel and making us back up and wait.
As far as jetting, I suggest you buy the Snow Performace Kit. Stage one will probably work. Right now I have the 600hp jet in mine. Don't worry about distro with the blower. Mine is plumbed under the primary only and it seems to hit all 8 just fine. You might even call and ask them if the sell jets seperate.
Re: Water/Meth Injection [Re: 6bblFLASH] #1411546
04/04/13 09:52 AM
04/04/13 09:52 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The spray barely get 6" out in the open air so don't worry about puddling.I flow tested mine for the fun of it.
Re: Water/Meth Injection [Re: Clanton] #1411547
04/04/13 04:44 PM
04/04/13 04:44 PM
N.E. Ohio
N.E. Ohio
All valid questions and comments, I`d be BS`ing if I said for sure it will work perfect.
As far as a Snow Kit I won`t need everything now,but that is what I wanted initially.
Nozzles are open ended choice LOTS of different vendors. McMaster Carr has really cheap ones. 4.00 each and only measure 3/4" long. Perfect for where I`m putting them.
If I understand it all: get a nozzle size in range,,,, use pressure to fine tune,,,,mixture is another fine tune tool.
Snow says " get AFR to 12.5 WITHOUT water,then with water ON should should lose no more than .5 AFR I.E.- 12.0 +. That will be safe. Then you can add timing/boost..... Experiment at your own risk from there
So general place to start is 625ml/10gph nozzle at about 60psi. Plan on using "BoostJuice" first then home brewed blends later.
Any other tpis/results/experiences?
Re: Water/Meth Injection [Re: 6bblFLASH] #1411548
04/07/13 06:00 AM
04/07/13 06:00 AM
N.E. Ohio
N.E. Ohio
Nobody uses water/meth?
Whats your tip size/HP. What mix are you using?
Before and after results?
Page 3 of 4 1 2 3 4
