Re: Water/Meth Injection
[Re: racealittle]
#1411529
04/02/13 08:11 PM
04/02/13 08:11 PM
I was just looking at the snow unit, $400 plus.
[Re: megajoltman]
#1411531
04/03/13 02:40 AM
04/03/13 02:40 AM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Mainbody: This area was hollow so I epoxied it solid. I may endup boring out the base and threading the nozzle directly into the mainbody IF it blows out the gasket ![](/ubbthreads/images/graemlins/luck.gif)
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#1411532
04/03/13 02:45 AM
04/03/13 02:45 AM
6bblFLASH
N.E. Ohio
Base is drilled and tapped for nozzle. Fitting just for example
[Re: 6bblFLASH]
#1411533
04/03/13 02:48 AM
04/03/13 02:48 AM
6bblFLASH
N.E. Ohio
Passage in side of mainbody intersects with passage out the bottom,also threaded to plumb water/meth to the nozzle.
[Re: 6bblFLASH]
#1411535
04/03/13 02:53 AM
04/03/13 02:53 AM
6bblFLASH
N.E. Ohio
Its just that simple. Took me all of an hour with a hand drill. Laided awake for HOURS coming up with the idea. I have`nt come up with any reasons why it won`t work ........ ![](/ubbthreads/images/graemlins/whistling.gif) Thoughts? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: challengermike]
#1411540
04/04/13 01:37 AM
04/04/13 01:37 AM
6bblFLASH
N.E. Ohio
Possible.but it can't puddle any worse than shooting against the wall of a 3in tube like everyone else does. No I'm not worried about distribution. Where things go inside there is anyone s. guess.I guess I could use a"T" and run two really small nozzles spraying outward. With 2 rotors spinning 10, 000rpm I doubt it will matter. Getting a nozzle from McMaster.625ml and a couple other sizes to play with. Their nozzle is very short and will bearly extend past bottom of the carb. giving it the max distance to fan out ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: 6bblFLASH]
#1411543
04/04/13 02:25 AM
04/04/13 02:25 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
4# This what I`m trying to avoid.
Is that a KB hyper piston?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Clanton]
#1411547
04/04/13 04:44 PM
04/04/13 04:44 PM
6bblFLASH
N.E. Ohio
All valid questions and comments, I`d be BS`ing if I said for sure it will work perfect. As far as a Snow Kit I won`t need everything now,but that is what I wanted initially. Nozzles are open ended choice LOTS of different vendors. McMaster Carr has really cheap ones. 4.00 each and only measure 3/4" long. Perfect for where I`m putting them. ![](/ubbthreads/images/graemlins/thumbs.gif) If I understand it all: get a nozzle size in range,,,, use pressure to fine tune,,,,mixture is another fine tune tool. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Snow says " get AFR to 12.5 WITHOUT water,then with water ON should should lose no more than .5 AFR I.E.- 12.0 +. That will be safe. Then you can add timing/boost..... Experiment at your own risk from there ![](/ubbthreads/images/graemlins/no.gif) So general place to start is 625ml/10gph nozzle at about 60psi. Plan on using "BoostJuice" first then home brewed blends later. Any other tpis/results/experiences? ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: 6bblFLASH]
#1411548
04/07/13 06:00 AM
04/07/13 06:00 AM
6bblFLASH
N.E. Ohio
Nobody uses water/meth? ![](/ubbthreads/images/graemlins/shock.gif) Whats your tip size/HP. What mix are you using? Before and after results? ![](/ubbthreads/images/graemlins/no.gif)
