Water/Meth Injection * UPDATE W/PICS*
#1411489
03/30/13 05:09 PM
03/30/13 05:09 PM
Posts: 3,862 N.E. Ohio
6bblFLASH
N.E. Ohio
Has anyone tried injecting it ABOVE the carb.? Don`t have room for a spray/plate under carb. Fishing for ideas
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Water/Meth Injection
[Re: 67_Satellite]
#1411494
03/31/13 09:42 AM
03/31/13 09:42 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Done some reading on the subject and it seems that it is effective injecting about anywhere. Some shoot it into the turbo inlet,various places in the inlet pipe, in the hat, under the carb.. Pick whichever works for you. http://www.theturboforums.com/threads/32...-Post-Them-Here
yes but he has a roots blower, no carb hat, just the big aircleaner assembly, not sure how'd you make that work. NOS has a "Top Shot" system that you might be able to modify. As for the jet it isn't that big. The guy that did my set up was going to drill and tap the carb base, but I got some 1/2 spacers and driled them instead.
[Re: Mr.Yuck]
#1411497
03/31/13 10:34 AM
03/31/13 10:34 AM
Posts: 4,492 northern,Ohio,USA
Clanton
northern,Ohio,USA
here' the NOS top shoot. I guess you could make something like this.
accept for all that mess on the middle!He will only need a single nozzle[625ml/min] and like the elbow coming in the baseplate pointed at the ventury or use a tab to mount the nozzle close to the opening.
[Re: Crizila]
#1411499
03/31/13 12:00 PM
03/31/13 12:00 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
Cool setup! can you post some pics of your pulley system for that blower? Interested in figuring a 10 rib system for something I'm working on.... Which water/meth injection kit are you going with? I was planning to use one from AIS. http://www.alcoholinjectionsystems.com/p...oduct_info.html
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: 6bblFLASH]
#1411500
03/31/13 12:35 PM
03/31/13 12:35 PM
Posts: 23,554 Here
jcc
No soup for you!!!
No soup for you!!!
Here
Not go off topic but are these setups ever used with e85?
I'm with Helmuth Hübener, and no soup is being served today.
[Re: mopardude318]
#1411502
03/31/13 03:02 PM
03/31/13 03:02 PM
6bblFLASH
N.E. Ohio
Right now I`m leaning towards a Snow Kit,However if its going to be a one-off custom I will just peice it together. I figure I can have it going around 150bucks.
I`ll share what photos I have. Homemade idler/tensioner.Pulley is from a Ford Expedition
[Re: 6bblFLASH]
#1411503
03/31/13 03:08 PM
03/31/13 03:08 PM
6bblFLASH
N.E. Ohio
2 Spring tensioner
[Re: 6bblFLASH]
#1411505
03/31/13 03:16 PM
03/31/13 03:16 PM
6bblFLASH
N.E. Ohio
Unfortunetly I have very few pics of my stuff apart. Its is a Dick Landy kit,so possibly you might find photos if you Google that. Some guys have redrilled Chevy pulley kits and machined/made new spacers . I`ve seen some DLI kits that were Chevy crank pulleys redrilled. Still had the 3-holes for GM stuff.
