Re: Spindle article in March '05 Mopar Muscle
[Re: Montclaire]
#14129
01/20/05 10:55 PM
01/20/05 10:55 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
.... I'm talking about a bolt-in, ready to go UCA that requires absolutely no thinking. "Install this upper arm on your (fill in the blank) mopar with the tall spindles and you will have the same geometry as if you used your stock or 73-76 a-body pieces." That's what they need to market, and they might even already make it. But that kind of advertising is what's going to sell parts. Then everyone wins.
That will not exist because an A-arm change ALONE will not do that.
The complete absolute infinitissimal 3-D geometry through it full range of motions will not have every geometrical result absolutely mirrored with a taller A-arm even if everything else is changed.
BUT changes can be made to make the handling and overall resulting behavior the same. Because there are so many input varibles in suspension design, there are many different paths to take to get to the same place.
[Re: SattyNoCar]
#14130
01/20/05 10:56 PM
01/20/05 10:56 PM
autoxcuda
So Cal
The guy TAcare?? from Colorado plotted this out and posted it here more than once. Bill Reily spend the time to measure a car and put the numbers in an impressive computer display. People that have experience in suspension design understand the small height change is not a big deal and will bring a slight camber gain. Why spend 15-30 hours of effort to prove a web arguement? Quote:
Glad to see some responses!
As for the article having been known over at bigblockdart.com, why hasn't anyone mentioned it before? I can't say I've read ALL the spindle threads here, but the ones I read, there was never any mention of someone having proved the tall spindles will work. Its always turned into a pissing match with a bunch of guys just saying stuff like 'I've used them on my car for years'.
[Re: DoctorDiff]
#14131
01/20/05 11:01 PM
01/20/05 11:01 PM
The UCA is redesigned so the upper ball joint is plumb when used with taller knuckles.
I don't think I understand this. Unless you mean that the UCA ia a touch longer than stock so that the ball joint won't "overangle" as claimed by Ebooger. Of course no one has proven that to be a problem and I believe Dulcich did a little research into ball joint angles and pretty much concluded that wasn't an issue.
Thor
[Re: DoctorDiff]
#14132
01/20/05 11:03 PM
01/20/05 11:03 PM
autoxcuda
So Cal
you mean the UCA ball joint socket is tilted slightly. So the range of angles the ball joint at factory suspension height is not changed.
But this is not absolutely necessary in reality. But if you were making an new A-arm you should include it and that's why Dick added it. It's a nice to have, but not a must have.
Those UBA ball joint can take a lot of angle. Most every circle track car runs very large angles on those very same K772 ball joints.
#14133
01/20/05 11:08 PM
01/20/05 11:08 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
Let's just be honest here. What you meant to say was, "some homeless dude wrote it down on a napkin and gave it to Dulcich, who then just reprinted it verbatim in MM without reading it." I'm not saying it's incorrect information. I'm just saying that I doubt Dulcich concluded anything.
[Re: AndyF]
#14135
01/21/05 03:17 AM
01/21/05 03:17 AM
Correct. Dick tweaked the boss for the upper ball joint a tad when he designed these arms so that they duplicate the static ball joint angle at some presumed ride height. (probably a tad lower than stock if I know the way that Dick thinks)
It doesn't make the geometry the same as stock since the taller knuckle alters that, it is designed to keep the ball joint in a narrower window of angle travel.
would i be correct in assuming that these 'new' arms would 'be off' a little bit on A body spindles?
[Re: 71charger]
#14138
01/21/05 06:00 PM
01/21/05 06:00 PM
Pauls69
super gas
super gas
i read the bigblock.com article & it was very refreshing to read some actual tests vs old wives tales. although parts of the article were a little out of my depth, the point was it's ok to run later model disk brakes ("B") on our old mopes. what's more dangerous, some nuances that most drivers won't notice, or someone tooling around with 4 wheel drum brakes having to make a panic stop? good work bigblockdart & MM!
[Re: Montclaire]
#14141
01/25/05 10:03 AM
01/25/05 10:03 AM
I said exactly what I meant to say. If you got issues use your own words and don't drag me into your problems.
You are one of the people I was referring to with the ideological axe to grind. Your information is less than useful and not based on any FACTS.
So go stroke your ego elsewhere and keep me out of it.
Thor
