Re: 70 318 man. trans, A, B or E build sheet question
[Re: twodoorpost]
#1410304
03/28/13 01:40 PM
03/28/13 01:40 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
I have an original 4895 Carter and it is identical to a 4721 and 4722, other than the dash pot, etc on the 4721 and some minor internals. A 4894 Carter, of which I have several is a much bigger carb. So yes, it is misidentified in the 70 book, but if you compare the breakdown listings for a 4721, 4722 and 4895, you will see that they are very similar, unlike a 4894 and its "cousins" Still need that broadcast sheet to sort everything out.
