3/8" pushrods with Stealth heads? #1409911
03/27/13 05:43 PM
03/27/13 05:43 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Can these be used? I've heard that you must use 5/16"
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 3/8" pushrods with Stealth heads? [Re: 68LAR] #1409912
03/27/13 07:09 PM
03/27/13 07:09 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I found I could not get 3/8" pushrods to clear the heads with 1.5 ratio rockers. I had to do some filing/grinding to get them to clear. When I fitted 1.6 ratio rockers I went back to 5/16" pushrods so I didn't have to grind them again.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: 3/8" pushrods with Stealth heads? [Re: 68LAR] #1409913
03/27/13 07:10 PM
03/27/13 07:10 PM
Penna
70satelliteguy Offline
Penna
68LAR, I'm working on this stuff myself right now. From what I understand in order to use 3/8 push rods with Stealth heads you have to open up the intake push rod passage. The exhaust is supposed to be ok. I also understand that 5/16 will work without modification to the heads and you can use them if your spring pressure is not too high . I am planing on using 5/16 push rods with the stock springs that came with the heads(checked out by my machine shop)and the Comp XS274 cam 502/236 intake and 520/242 exhaust. This was OK'd by fast68(Dwayne) of Porter Racing heads. If I am incorrect someone please correct me!
mIke
Re: 3/8" pushrods with Stealth heads? [Re: 70satelliteguy] #1409914
03/27/13 07:35 PM
03/27/13 07:35 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Thanks,
A friend of mine is about to install a set of the Stealth heads and wants to run the 3/8" push rods. He was told that they won't work. He runs the same spring that I do. 150 on the seat and 375 open. If only the intake side needs opened to make the 3/8's work he may go that route. I'd be skeptical with a 5/16" working at 6500+ rpm. He is also going to be running the 1.6 rocker arms. What area of the pushrod passages needs opened, using a clock for positioning. Like 12 o'clock, 3, 6 & 9 o'clock? My Eddy heads needed very little removed from the 9 o'clock position. And I mean very little!
By the way he is running a solid flat tappet comp cam.
Re: 3/8" pushrods with Stealth heads? [Re: 68LAR] #1409915
03/27/13 07:39 PM
03/27/13 07:39 PM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
It depends on the height of the lifter cup, with a HYD roller a very small amount of clearancing to be done right at the top of the push rod hole, just touches when using COMP rockers,,, remember the pushrod moves away when lift begins.
Re: 3/8" pushrods with Stealth heads? [Re: Mick70RR] #1409916
03/27/13 07:44 PM
03/27/13 07:44 PM
MN
hemidup Offline
hemidup  Offline
MN
I've also have had clearance issues with Steath heads and 5/16" pushrods and only on the later castings. The first time I thought it was a fluke so I didn't mind pulling the heads off and rework them. The 2nd time it happened I was a little upset. Since then I automatically clearance them right out of the box.
Jerry Williams.
Re: 3/8" pushrods with Stealth heads? [Re: 68LAR] #1409917
03/27/13 09:48 PM
03/27/13 09:48 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use Crane 3/8th's pushrods and Crane iron 1.5 rockers with my Stealth's. I'm using the Mopar 296/557 cam,and Comp springs and retainers/locks. I had to open the intake pushrod holes a bit,but all I did was mock up the heads,and used a marker where they didn't clear and ground away.Wasn't much,and I maybe had an hour's worth of time doing so.
Nautilus Racing-
Re: 3/8" pushrods with Stealth heads? [Re: Chris2581] #1409918
03/27/13 10:06 PM
03/27/13 10:06 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
Cab had a bunch of pics of the 3/8s hitting stealths
74 dart sport 440 www.Csucarbs.com
Re: 3/8" pushrods with Stealth heads? [Re: 68LAR] #1409919
03/27/13 10:32 PM
03/27/13 10:32 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Not to be a sarcastic pr!ck, but you need to clearance the part of the head that hits the pushrod. Different rockers, lifter type can all affect where the clearance issues will spring up. My favorite method is to use some blue dykem on the head, install it with a gasket and a few bolts, install the lifters, pushrods and rockers and roll the engine over a few times. This will usually leave a shiny spot on the head where you need to address things. If the interference is bad enough you won't even be able to get the rocker to seat on the pushrod, and if you try to force it, expect a bent pushrod.
Hope it all works out well for you.
Re: 3/8" pushrods with Stealth heads? [Re: dodgeboy11] #1409920
03/27/13 10:56 PM
03/27/13 10:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have a set of the first heads.My 440 rins .588 cam with solids.I run Crane 3/8 alloy rods with Erson iron rockers.Mine just clear.I ran it for a while after the install and rechecked it when I adjusted the valves.Never saw any rubbing.Rocky
Chrysler Firepower
Re: 3/8" pushrods with Stealth heads? [Re: therocks] #1409921
03/27/13 11:13 PM
03/27/13 11:13 PM
MN
hemidup Offline
hemidup  Offline
MN
You also need to consider push rod deflection. Also, the only issue I had with their first casting's was h2o dripping on the floor at the dyno. The head was cracked from the git go, but 440 Source stepped up to the plate and replaced it.
Jerry Williams.
Re: 3/8" pushrods with Stealth heads? [Re: 68LAR] #1409922
03/28/13 02:56 AM
03/28/13 02:56 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think that I used some Smith Brothers 5/16" 0.080" wall pushrods on the 505" stroker with stealth heads, but using Isky 8005A springs, 135 seat, 375 @ 0.600". Comp XE286HR (hydraulic roller),0.617"/0.614" lift with 1.7:1 rockers. Had to clearance the pushrod holes to use the 1.7:1 rocker arms.
Re: 3/8" pushrods with Stealth heads? [Re: 68LAR] #1409923
03/28/13 09:28 AM
03/28/13 09:28 AM
Delray beach, Florida
P
Performance Only Offline
P
A good quality 5/16 .080+ wall pushrod will easily handle 450 lbs open pressure and deflection isn't a problem. If it makes you feel better you can buy them with a thicker wall also. I don't see any reason to make it a bigger project than it should be for a flat tappet or hydraulic roller application. For a aggressive solid roller i'd step up to 3/8 pushrods though.
machine shop owner and engine builder
Re: 3/8" pushrods with Stealth heads? [Re: Performance Only] #1409924
03/28/13 11:40 AM
03/28/13 11:40 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Thanks again to all for the info.
I have already passed on a suggestion about the .080" wall, 5/16" push rods. I think this would be a trouble-free install and with minimum hassle. Of course, everything will be checked and double checked before the final install....
