Denso alternator swap #140969
10/24/08 01:04 PM
10/24/08 01:04 PM
Sacramento, CA
Bdrainy Offline OP
Bdrainy  Offline OP
Sacramento, CA
I am considering doing to denso alternator swap and was looking at the info in the tech archives from AndyF.
I see that the kit is sold through mancini to mount it, but looking at the picture the mounts look the same as whats on my 383 now. Is the denso a straight bolt on, or do I need to change the mounts? The picture may just be tricking me, but they look exactly the same to me...
http://www.moparts.org/Tech/Archive/elec/34.html
Re: Denso alternator swap [Re: Bdrainy] #140970
10/24/08 03:08 PM
10/24/08 03:08 PM
AndyF Offline
AndyF  Offline
The mounts look the same but are different. The spacer lengths are different and the bends are different. The kit is made that way so it looks stock to the casual observer but stock parts won't fit without rework.
Re: Denso alternator swap [Re: Bdrainy] #140971
10/24/08 03:23 PM
10/24/08 03:23 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
I dont know about anyone else, but I put an denso IR alt. off a toyota prerunner and just bolted it up to the stock mounts! Cant remember if I shimed it or not but it fits great.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Denso alternator swap [Re: Bdrainy] #140972
10/24/08 04:36 PM
10/24/08 04:36 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Andy's mount sits lower than stock.
Re: Denso alternator swap [Re: Lefty] #140973
10/24/08 04:42 PM
10/24/08 04:42 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I love how clean your engine compartment is but I do question the location of the fuel filter...
Possible fire hazard on top of the alternator like that.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Denso alternator swap [Re: HealthServices] #140974
10/25/08 01:41 PM
10/25/08 01:41 PM
Lefty Offline
Lefty  Offline
It was below the stock alternator before the swap, it's been moved but the pic is before I replumbed the filter. Very good point however.
Re: Denso alternator swap [Re: Lefty] #140975
12/25/08 05:05 PM
12/25/08 05:05 PM
NC, Mebane
rcannon440 Offline
rcannon440  Offline
NC, Mebane
What amp Denso Alternator did you use?
Re: Denso alternator swap [Re: kilroy] #140976
12/25/08 05:10 PM
12/25/08 05:10 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Mine too.
Re: Denso alternator swap [Re: rcannon440] #140977
12/25/08 06:17 PM
12/25/08 06:17 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
60 amp..here is what i have
Re: Denso alternator swap [Re: MoparforLife] #140978
12/25/08 09:38 PM
12/25/08 09:38 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Mine too.
me too. except I used one off an 02 dodge ram van, 130 amp. I did have to trim one spacer, though. took about 5 minutes with a dremel.
It's a long read, but it shows how I did it and what parts I used. I was into the whole thing for under 150. but I also bought stuff to go from single to dual field:
http://www.moparchat.com/forums/showthread.php?t=61642
Re: Denso alternator swap [Re: Pool Fixer] #140979
12/26/08 12:38 AM
12/26/08 12:38 AM
Stratford nj
cudadan Offline
cudadan  Offline
Stratford nj
i got mine from a 98 dodge intrepid, 120 amp , it will power anything ya want, it works great on my car
Re: Denso alternator swap [Re: cudadan] #140980
12/26/08 12:11 PM
12/26/08 12:11 PM
Saskatchewan, Canada
barracudabob Offline
How do you wire it? Thanks, Bob
Re: Denso alternator swap [Re: barracudabob] #140981
12/26/08 12:29 PM
12/26/08 12:29 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I just got one. 90 amp. I used the p/n for an 89 diplomat so that it would come with a v-belt pulley. To install it on my eddie headed 360 smallblock I had to do a bunch of stuff:
-take off the plastic back cover
-remove the brass standoff on the + connection and cut down the stud
-make a bracket to extend the outboard mount down (the stock bracket hits the big fan that is installed under the pulley. I used two pieces from the front and back to extend the mounting point about 4" down. I think the 'andy f' bracket has more circular roundness to come up from the bottom instead of over from the side)
-shave the front of the inboard mount about 1/8" to prevent the ceramic piece on the back from rubbing the head
-Install good ground wire and fat positive wire going straight to the battery (in addition to the stock + wire) to prevent ammeter/underdash meltdown
I did all these things last week, and fired her up and let her get warm. No problems, voltmeter reads 13 steady.
kevin in Philly
Re: Denso alternator swap [Re: radar] #140982
12/26/08 10:26 PM
12/26/08 10:26 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
small blocks are tight with stock heads and a stock alt. I was at a friends shop and he had an cuda with a small block and eddy's. he had to shave the head to get the stock alt to fit. Denso? forget it on that one. that is a situation where you need special brackets. I think they ended going with something out of a ford. could have been a denso, don't know.
Re: Denso alternator swap [Re: Bdrainy] #140983
12/26/08 10:33 PM
12/26/08 10:33 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I needed more amps too, but took a different route. I had my squareback, dual-field alternator's stator rewound and heavy duty diodes installed at the local alternator shop for under $200.
Of course it bolts right up to the stock mount and looks bone stock for a 1970. It puts out 70 amps at idle and just over 125 amps above 2000 rpm. I upgraded the wiring and did the bulkhead/ameter bypass sugested in the article on Alpar.
Re: Denso alternator swap [Re: Pool Fixer] #140984
12/26/08 10:36 PM
12/26/08 10:36 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
90a Denso
Stock brackets
Stock heads
Only modification was to trim the stud on the back.
Just how it worked out for me on a Small Block. I would still like to get my hands on a smaller pulley for this alternator..or a larger crank pulley. We'll see, may be serpentine on a magnum block soon enough. But the charging at idle with 90w H4 lights on, stereo, electric fuel pump, and my fan pullin 25-30a...it's not quite enough at idle.
http://www.goodysgotacuda.com/DensoUpgrade.html
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Denso alternator swap [Re: Pool Fixer] #140985
12/27/08 12:17 AM
12/27/08 12:17 AM
AndyF Offline
AndyF  Offline
Actually the Denso 60 amp alternators fit better on a SB Mopar with Edelbrock heads than do the original type alternators. A SB with Eddy heads is a great candidate for a Denso swap.
Re: Denso alternator swap [Re: GoodysGotaCuda] #140986
12/27/08 01:00 AM
12/27/08 01:00 AM
Delmont, Pa.
SRT8Challenger Offline
Delmont, Pa.
Goody, that is one clean shop you have there!Looks great! Nice and tidy, no wires hanging!!
ED
Re: Denso alternator swap [Re: SRT8Challenger] #140987
12/27/08 01:19 AM
12/27/08 01:19 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
ED
Why thank you,
Now I just have to get around to welding up the holes and smoothing the bay up some.
Re: Denso alternator swap [Re: GoodysGotaCuda] #140988
12/27/08 03:36 PM
12/27/08 03:36 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Larger crank pulley is probably what will be easier. I don't know that smaller alt pulleys are easy to get.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
