Changing intake manifold #1409498
03/26/13 07:46 PM
03/26/13 07:46 PM
wv
73bbroadrunner Offline OP
wv
I am changing my mopar performance dual plane out for a performer rpm on my 400 and wandering if I need to remove and reseal the valley pan or can I leave it alone? (about 1,000 miles on rebuilt motor) Do I need to use sealent on the paper gasket between valley pan and intake?
Re: Changing intake manifold [Re: 73bbroadrunner] #1409499
03/26/13 08:37 PM
03/26/13 08:37 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I would plan on resealing/replacing the valley pan. Chances are you will break the seal between the pan and the heads somewhere causing a vacuum leak. Depending how much sealant is on the pan, you may even end up bending the pan so I would just go ahead and have an extra one on hand just in case. $14 isn't too much to spend so you don't have to pull the intake twice to get it to seal...ask me how I know.
I don't use the paper gaskets at all. I just use the copper RTV on both sides of the pan and call it a day.
Re: Changing intake manifold [Re: cjskotni] #1409500
03/26/13 08:55 PM
03/26/13 08:55 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I don't use the paper gaskets either. I've had the intake off mine a total of 3 times...same gasket...no problems.
Re: Changing intake manifold [Re: 73bbroadrunner] #1409501
03/26/13 09:25 PM
03/26/13 09:25 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
R and R the same intake ? ... should not be a problem. A diff intake .... is taking a chance.
Re: Changing intake manifold [Re: dOc !] #1409502
03/26/13 09:28 PM
03/26/13 09:28 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I had a DP4B off twice(don't ask...cam issue)then I replaced it with a RPM.
Re: Changing intake manifold [Re: 73bbroadrunner] #1409503
03/27/13 10:31 AM
03/27/13 10:31 AM
scratchnfotraction Offline
I used a felpro 1215 for my 440/RPM intake.
used some gasket tack on the pan side of gaskets only.
I have R&R the intake 2x now and the gaskets stay put stuck to the pan.
get the felpro HP valley pan for the B engine with heat block off/4 paper gaskets.
