Re: 1972 Plum Purple Dart for Neices
[Re: HUSTLESTUFF]
#1409036
03/29/13 02:26 AM
03/29/13 02:26 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
Rear end was re-assembled and put back in after underside epoxied.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: HUSTLESTUFF]
#1409037
03/29/13 02:27 AM
03/29/13 02:27 AM
HUSTLESTUFF
NORTHERN CA
Brian before starting on body work
[Re: HUSTLESTUFF]
#1409038
03/29/13 02:30 AM
03/29/13 02:30 AM
HUSTLESTUFF
NORTHERN CA
The underside rear of the car will be done when we get some new fuel line and install the gas tank. The engine compartment is ready for epoxy. Tomorrow we'll get to the roof and trunk. Ed will work on the engine and I'll try to get to the suspension. Man I'm tired. Stayed up way too late catching up. Oh yea, the crawfish were delicious.
[Re: MuuMuu101]
#1409040
03/29/13 03:38 AM
03/29/13 03:38 AM
Posts: 6,309 colorado
a12superbee
colorado
Mind if I ask how much $$ you expect to spend and how many manhours you'll put in?
I can't afford this.
mark
[Re: a12superbee]
#1409041
03/29/13 10:47 AM
03/29/13 10:47 AM
HUSTLESTUFF
NORTHERN CA
I'll probably have under $5000 including the purchase price. I have $2150 in interior weather striping and parts. Another $450 in paint. and probably $300 in shop supplies like sandpaper etc. In my spreadsheet I have 175 man hours, but more than likely it will go 250. Remember there is no rust repair and that save a ton. Even the lower 1/4's and area under the battery tray are completely rust free.
Back to work!!!!!!!
[Re: a12superbee]
#1409043
03/30/13 03:02 AM
03/30/13 03:02 AM
HUSTLESTUFF
NORTHERN CA
Got alot done today. Ready for paint in engine compartment trunk and jambs.
Re: 1972 Plum Purple Dart for Neices *DELETED*
[Re: HUSTLESTUFF]
#1409044
03/30/13 03:02 AM
03/30/13 03:02 AM
HUSTLESTUFF
NORTHERN CA
Post deleted by HUSTLESTUFF
[Re: HUSTLESTUFF]
#1409045
03/31/13 12:26 AM
03/31/13 12:26 AM
HUSTLESTUFF
NORTHERN CA
Didn't have time to post so I'll catch up on yesterday (day 3).
The rear end is back in the car. Have to put nuts on after painting them.
[Re: HUSTLESTUFF]
#1409046
03/31/13 12:31 AM
03/31/13 12:31 AM
HUSTLESTUFF
NORTHERN CA
We sanded the deck lid and cowl to prep for epoxy.
[Re: HUSTLESTUFF]
#1409047
03/31/13 12:33 AM
03/31/13 12:33 AM
HUSTLESTUFF
NORTHERN CA
Then we decided to pull the interior before prepping trunk and jambs. How is this for a mint build sheet. Hamatrack plant.
[Re: HUSTLESTUFF]
#1409049
03/31/13 12:35 AM
03/31/13 12:35 AM
HUSTLESTUFF
NORTHERN CA
And perfect floor pans. Even I haven't seen them this clean.
[Re: HUSTLESTUFF]
#1409051
03/31/13 12:38 AM
03/31/13 12:38 AM
HUSTLESTUFF
NORTHERN CA
Then we started scotch brighting the engine compartment, trunk and door jambs.
[Re: HUSTLESTUFF]
#1409052
03/31/13 12:40 AM
03/31/13 12:40 AM
HUSTLESTUFF
NORTHERN CA
A little more work on the vent grille and we were ready for epoxy.
[Re: HUSTLESTUFF]
#1409054
03/31/13 12:42 AM
03/31/13 12:42 AM
HUSTLESTUFF
NORTHERN CA
A couple of tips from the pro and Steve was off and painting.
[Re: HUSTLESTUFF]
#1409055
03/31/13 12:43 AM
03/31/13 12:43 AM
HUSTLESTUFF
NORTHERN CA
I had to put in my two cents as well...
