426 Hemi head with damage #1408271
03/24/13 10:01 PM
03/24/13 10:01 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
I have a Hemi head I would like opinions on, has two issues. First pic shows where damage is, then I'll post close up shots. Give me ideas on best way to repair. Thanks!
Re: 426 Hemi head with damage [Re: Bull1tt] #1408272
03/24/13 10:03 PM
03/24/13 10:03 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
this is close-up of green area circled.
Re: 426 Hemi head with damage [Re: Bull1tt] #1408273
03/24/13 10:04 PM
03/24/13 10:04 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
this is bolt area circled in red
Re: 426 Hemi head with damage [Re: Bull1tt] #1408274
03/24/13 10:30 PM
03/24/13 10:30 PM
my state of mind
jimkn Offline
jimkn  Offline
my state of mind
jb weld honestly i wouldnt worry about it to much unless your building a serious race motor as there for the valley studs, maybe if you want to sleep better have them cold stitched & forget about it!!!
" if you didn't own it since new then the fender tag is fake "
Re: 426 Hemi head with damage [Re: jimkn] #1408275
03/24/13 10:37 PM
03/24/13 10:37 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
this long crack can be felt with your fingernail.
Re: 426 Hemi head with damage [Re: Bull1tt] #1408276
03/24/13 11:21 PM
03/24/13 11:21 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
I can fix this head but have questions.
The long one you said you can catch your nail on it ? Does it keep going off the head deck and around and down across the intake seat and pass into the throat below the seat ?
The head stud cracks I would stitch pin them on both sides of the threaded hole to stop cracking and then drill and install a time sert. I would also stitch pin the deck crack and possibly install a new seat if needed. After repair the head would have to be surfaced to clean up the deck surface. If the deck crack goes well into the intake throat area where you cannot get to it then the head will have to be welded with cast iron rod to fix it right which is a more extensive repair.
MLR426
Re: 426 Hemi head with damage [Re: MLR426] #1408277
03/25/13 06:21 PM
03/25/13 06:21 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
I'll go over where I have these parts tomorrow. Then I can answer your questions.
Re: 426 Hemi head with damage [Re: Bull1tt] #1408278
03/25/13 07:36 PM
03/25/13 07:36 PM
South Carolina
FM3_1970 Offline
FM3_1970  Offline
South Carolina
Did you mean to post this in the Ebay/WIW section? Might get more opinions if it was in Q & A or Race.
Re: 426 Hemi head with damage [Re: MLR426] #1408279
03/25/13 11:11 PM
03/25/13 11:11 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
MLR426
I went and looked this head over tonight. I could not see any sign of the crack anywhere other than the deck. No sign down to the seat area or beyond. Even had an extra set of eyes from a buddy studying as well.
Re: 426 Hemi head with damage [Re: FM3_1970] #1408280
03/25/13 11:14 PM
03/25/13 11:14 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Move it to the Q&A, fine by me!
Re: 426 Hemi head with damage [Re: Bull1tt] #1408281
03/26/13 08:55 PM
03/26/13 08:55 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
.....I went and looked this head over tonight. I could not see any sign of the crack anywhere other than the deck. No sign down to the seat area or beyond. Even had an extra set of eyes from a buddy studying as well.
When it comes to cracks in Hemi heads I trust nothing other than dye penetrant. Have them DP'd and then make a decision.
Re: 426 Hemi head with damage [Re: Bull1tt] #1408282
03/26/13 10:40 PM
03/26/13 10:40 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
MLR426
Have them dyed or mag them and pressure test, the tricky part is the crack is on a fire ring area. Are you sure it's a crack ?? Strange place for crack.
MLR426
Re: 426 Hemi head with damage [Re: MLR426] #1408283
03/26/13 11:00 PM
03/26/13 11:00 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
MLR426
MLR426
It's like somebody tried to pry the head off an engine with those two bolts still in!
Re: 426 Hemi head with damage [Re: Bull1tt] #1408284
03/27/13 02:06 AM
03/27/13 02:06 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Mag it.It can be welded and will be as good as new if done properly.If there isn't anyone local to you who can do it I have someone up here who can.It will need to be resurfaced.
Leave the gun.......take the Cannoli's....Mike
