Fuel prices in your area? #1406939
03/23/13 09:07 AM
03/23/13 09:07 AM
tboomer Offline OP
tboomer  Offline OP
What are you guys paying for fuel? I priced VP 110 at 7.75 a gallon here...Thought about switching to E-85 or alky but I would have to race steady to justify the initial expense...And that won't happen with weekend entry fees of 165.00 or 90.00 a day. So we wil run just a couple of events for fun...
Re: Fuel prices in your area? [Re: tboomer] #1406940
03/23/13 09:17 AM
03/23/13 09:17 AM
KY
jeffs67 Offline
jeffs67  Offline
KY
Sunoco Supreme 112 is $8.60 gallon in 54 gallon drums.
Re: Fuel prices in your area? [Re: jeffs67] #1406941
03/23/13 09:24 AM
03/23/13 09:24 AM
tboomer Offline OP
tboomer  Offline OP
Ouch!! 440Jim sent me some good links on E-85 and I have a pump within walking distance of my home. Right now that is 2.85 a gallon..
Re: Fuel prices in your area? [Re: tboomer] #1406942
03/23/13 10:08 AM
03/23/13 10:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
$3.30a gal for E-85 here... I havent priced 110 in
a FEW years now.... you can change over your carb to
E-85 for pretty cheap... there are sites that give you
step by step and within a year you would recoup your
money
Re: Fuel prices in your area? [Re: MR_P_BODY] #1406943
03/23/13 10:12 AM
03/23/13 10:12 AM
tboomer Offline OP
tboomer  Offline OP
Hey,Raff! The other day,E-85 here is 2.95..And I would hate to ruin a good Dominator!! I see Quick Fuel has the kit for it...But I am sure that I don't have enough fuel pump. I have to change my fuel line from aluminum to braided...It has a nasty kink!
Re: Fuel prices in your area? [Re: tboomer] #1406944
03/23/13 10:40 AM
03/23/13 10:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt have to change pumps because I had enough
flow.. I run a pair of 150 black Holley pumps in
parallel.. had them on there for gas and they are
still working fine... yeah you would have to fix the
kink(but you should anyways)
Re: Fuel prices in your area? [Re: tboomer] #1406945
03/23/13 01:50 PM
03/23/13 01:50 PM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
In Texas it is $9.50 a gallon at track and a little cheaper in 54 gallon drum. I was wondering how much more e-85 do you burn compared to gasoline? I was told that to warm the motor a long idle time is required and will burn a little more than twice for pure alcohol.
Re: Fuel prices in your area? [Re: oldtimer5151] #1406946
03/23/13 02:09 PM
03/23/13 02:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With E-85 you burn 30% more fuel over gas.. alky
is roughly 2 times over gas... both have a little
harder time getting the temp up but with alky most
guys run a lean out valve to build heat... I let my
engine run a bit longer without the fan and keep the
water pump running to keep the block and rad at about
160 while in the lanes... I always fire it up to move
forward and let it run a minute before I shut it down
Re: Fuel prices in your area? [Re: MR_P_BODY] #1406947
03/23/13 04:13 PM
03/23/13 04:13 PM
Aubrey, Texas
O
O
Aubrey, Texas
Thank You.
Re: Fuel prices in your area? [Re: oldtimer5151] #1406948
03/24/13 10:54 AM
03/24/13 10:54 AM
tboomer Offline OP
tboomer  Offline OP
Mike...Do you have a pic of your fuel pump setup? Thanks!!
Re: Fuel prices in your area? [Re: tboomer] #1406949
03/24/13 11:14 AM
03/24/13 11:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No I dont... never figured it was worth a pic ... LOL
Re: Fuel prices in your area? [Re: MR_P_BODY] #1406950
03/24/13 11:21 AM
03/24/13 11:21 AM
tboomer Offline OP
tboomer  Offline OP
Its all good! So...In theory,it sounds like I could just add another 140 gph pump and get a different carb..
Re: Fuel prices in your area? [Re: MR_P_BODY] #1406951
03/24/13 11:27 AM
03/24/13 11:27 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Fuel prices in your area? [Re: MR_P_BODY] #1406952
03/24/13 11:27 AM
03/24/13 11:27 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I don't know why more people when they need a bigger pump don't just add a 2nd pump in place of **** canning the one they already have an spending 2-3 times as much $$$ for the same results!Two Holley blue pumps in-line with a 1/2" line can supply enough gas for most engines.I like to come out of the fuel cell with one line to each pump then one line out of each pump about a foot into a good Y block.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Fuel prices in your area? [Re: tboomer] #1406953
03/24/13 11:35 AM
03/24/13 11:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your right... I run the 2 lines out of the fuel cell
to the inlet of the pumps... then used a Y fitting
on the outlet side to a single 1/2" line going to my
regulator up front then 2 lines to the carb.. I run
a return line back to the tank(my return is 3/8)
Also I opened up the vent more.. I use another vent
line in the top of the cell with a loop in it
Re: Fuel prices in your area? [Re: MR_P_BODY] #1406954
03/24/13 11:43 AM
03/24/13 11:43 AM
tboomer Offline OP
tboomer  Offline OP
Thanks,guys!! I do know a couple of racers that have ran a pair of the Holley blue pumps and both cars are faster than me. Raff...You run just one regulator instead of two like the illustration John provided? Correct?? I do have a spare Holley blue in the garage...
Re: Fuel prices in your area? [Re: tboomer] #1406955
03/24/13 11:46 AM
03/24/13 11:46 AM
PA.
"Little"John
"Little"John
PA.
I ran it like that for years well into the 9's Ted. Two holley blue pumps and one regulator up front.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Fuel prices in your area? [Re: pittsburghracer] #1406956
03/24/13 11:50 AM
03/24/13 11:50 AM
tboomer Offline OP
tboomer  Offline OP
Both cars I know are into the 9's,John...I could shelve my dominator system and look for a 4150 carb. I have a nicely done Victor intake for a 4150 series here...
Re: Fuel prices in your area? [Re: tboomer] #1406957
03/24/13 12:01 PM
03/24/13 12:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just the one regulator(Mallory 4 port)
Re: Fuel prices in your area? [Re: MR_P_BODY] #1406958
03/24/13 12:15 PM
03/24/13 12:15 PM
tboomer Offline OP
tboomer  Offline OP
Thanks,Raff! How cool would it be to go less than a block to get a barrel of fuel? There is also an ethanol plant nine miles north of me but I don't know if they sell direct...
