Will a 275-60-15 fit on a 71 scamp? #1406183
03/21/13 05:04 PM
03/21/13 05:04 PM
southern illinois
Y
yellowscamp Offline OP
Y
southern illinois
Will a 275-60-15 fit on a 71 scamp. I have moved the springs inboard 3 inches. THe wheel wheels are stock and the wheel openings are stock. If they will fit what wheel backspace should i use. THe rearend is a stock width 8 3/4.
Re: Will a 275-60-15 fit on a 71 scamp? [Re: yellowscamp] #1406184
03/21/13 06:05 PM
03/21/13 06:05 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Not easily, you'll need 4.5 or 5 inch BS on an 8 inch wheel with the springs moved like that, but you still have the problem with the inner and outer qtr. You could bend the lip up and be real carfull plus do some trimming on the inside. Keep in mind that is a tall tire for an A body. It'll be really tight.
Re: Will a 275-60-15 fit on a 71 scamp? [Re: yellowscamp] #1406185
03/21/13 06:46 PM
03/21/13 06:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You should mini tub it if you moved the springs inboard , you are still hindred by the size of the wheel wells .
Re: Will a 275-60-15 fit on a 71 scamp? [Re: JohnRR] #1406186
03/21/13 08:00 PM
03/21/13 08:00 PM
Frederick, MD
moparguy1967 Offline
Frederick, MD
I was only able to fit a 235-60r15 under my car.
Re: Will a 275-60-15 fit on a 71 scamp? [Re: moparguy1967] #1406187
03/21/13 08:17 PM
03/21/13 08:17 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I think you will have to move in the tubs to the frame rail, in stock form on my kids 71 Scamp i got a 26 x 8.5 slick and thats all the you could get in there
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Will a 275-60-15 fit on a 71 scamp? [Re: 65signet] #1406188
03/21/13 09:31 PM
03/21/13 09:31 PM
southern illinois
Y
Y
southern illinois
WHat about a 255-60-15. would it fit?
Re: Will a 275-60-15 fit on a 71 scamp? [Re: yellowscamp] #1406189
03/21/13 09:37 PM
03/21/13 09:37 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had 255 60s in my 67 Dart. The wheelwells are identical. I had a custom 15x8 rally wheel with 6 inches of BS with the springs in the stock location.
They fit with about 3/4" of room on each side. The 275s would probably fit since they are about 5/8" wider overall. This equates to less that 3/8" wider per side.
I wouldn't expect to do any cornering or off road trailblazing though.
Re: Will a 275-60-15 fit on a 71 scamp? [Re: Kern Dog] #1406190
03/22/13 10:33 AM
03/22/13 10:33 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Was this with a stock a-body rearend?
