Re: replacement vacuum adv. unit [Re: JS23U] #1405987
03/25/13 07:58 PM
03/25/13 07:58 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
STANDARD VC187
ADVANCE STARTS 10.5
MAX ADV 8 DEGREES -10.5
15.5 HG
Shouldn't the max adv be 18 degrees?
Can anyone confirm that these replacement canisters are adjustable?
if it says 8 deg max advance, that would be 16 crank degrees. My understanding is that the cans with the "hex" housing end are adjustable
Re: replacement vacuum adv. unit [Re: torkrules] #1405988
03/25/13 08:21 PM
03/25/13 08:21 PM
Yes I'd want someone who has physically seen the # on a VC187 like my parts house saw 10L on a VC 188 since the printed material seems to be so bogus/inconsistant. I think the ones (Prestolite?) with the hex nipple can be unscrewed & washers added to slow the start of the curve, not sure how to bring it in earlier (weaker spring?). All the ones with the regular nipple I've ever checked the slope (not the total which is the # on the arm)) can be adjusted with a 3/32" allen wrench.
Re: replacement vacuum adv. unit [Re: RapidRobert] #1405989
03/26/13 09:15 PM
03/26/13 09:15 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Yes the older style can, like those used on dual point dist used shims to adjust the rate. The ones like the VC187 adjust with an allen key.
I actually bought on today. It is stamped 9L meaning it has 18 degrees crank advance. I actually have a Sun 400 distributor machine that I just rebuilt. It has a vacuum pump with a regulator and I mapped the curve from 10" hg to 20" hg. This was done with two and a half turns counter clockwise on the adjuster. I'll try to post it shortly. As I recall it was about 7 degrees advance at 17"
Re: replacement vacuum adv. unit [Re: torkrules] #1405990
03/26/13 09:44 PM
03/26/13 09:44 PM
Alright so for totals we have 10L (20 crank) on the VC 188 & 9L (18 crank) on the VC 187 . Seems closer than I would expect em to be
Re: replacement vacuum adv. unit [Re: RapidRobert] #1405991
03/26/13 10:16 PM
03/26/13 10:16 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Too bad there's not an 8L
Re: replacement vacuum adv. unit [Re: torkrules] #1405992
03/28/13 01:52 PM
03/28/13 01:52 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Here is the graph of the advance VS vacuum
Re: replacement vacuum adv. unit [Re: torkrules] #1405993
04/01/13 10:13 AM
04/01/13 10:13 AM
WILKES-BARRE PA
Joesixpack Offline
Joesixpack  Offline
WILKES-BARRE PA
Re: replacement vacuum adv. unit [Re: Joesixpack] #1405994
04/01/13 04:48 PM
04/01/13 04:48 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
just saw this one
http://www.ebay.com/itm/NOS-Mopar-vacuum...670&vxp=mtr
Looks like a 10L too
