oil pickup-sb #1405960
03/21/13 06:01 AM
03/21/13 06:01 AM
pennsylvania
poboyengineering Offline OP
pennsylvania
ive seen some oil pumps where the stock hole is plugged and a tube is fabbed into the cover. is there a problem with this? it seems that opening up the passages in the block is pointless unless the pickup tube is also enlarged, and the lack of material on the pump housing is the limiting factor. any experience, good or bad?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: oil pickup-sb [Re: poboyengineering] #1405961
03/21/13 11:33 AM
03/21/13 11:33 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I have one of the old pumps with the threaded hole in the pump cover for a straight pipe to a pickup. I have never found a pickup that would work. 2 0r 3 years ago a member here was building such a pickup but I never saw the finished product. Don't know if they were ever ready to sell or not. I would love to have one!!!!
Re: oil pickup-sb [Re: Blucuda413] #1405962
03/21/13 12:27 PM
03/21/13 12:27 PM
so ca
mikesiron Offline
mikesiron  Offline
so ca
Suction side of pump should allways be generious. But unless you have a rear sump pan you will not be able to pipe into the bottom of the pump. You can buy the pump cover from any pan manufacture that sell rear sump pans. Common in Circle track racing pans, The stock pump can be enlarged to 1/2 pipe (3/8 pipe is stock).
Re: oil pickup-sb [Re: mikesiron] #1405963
03/21/13 04:14 PM
03/21/13 04:14 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My Kevko rear sump pan came with a pump cover pickup assy.
Re: oil pickup-sb [Re: poboyengineering] #1405964
03/21/13 06:32 PM
03/21/13 06:32 PM
Guitar Jones Offline
You can buy the pickup from Canton that bolts to the pump as the cover. It's 5/8 and that's what you need. You can modify it from there to fit you pan.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: oil pickup-sb [Re: mikesiron] #1405965
03/22/13 10:54 PM
03/22/13 10:54 PM
Muncie
Racebuddy Offline
Racebuddy  Offline
Muncie
I have run two pick ups on a small block also. Some folks on here thought that was a terrible idea
Re: oil pickup-sb [Re: Racebuddy] #1405966
03/23/13 01:18 AM
03/23/13 01:18 AM
so ca
mikesiron Offline
mikesiron  Offline
so ca
I will say duel pick-up or 1/2 single helped lower my oil temp 15-25deg in my round track engines. also used crank scraper,and windage tray,
