Need help drag shock rear a body #1405700
03/20/13 11:31 PM
03/20/13 11:31 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Hello everyone
do they make a shorter rear drag shock for a demon, my problem is i put on a comp eng shock part #247-2730 and it's to long when i attach it,....it sit bolt hole to hole collapsed looking for any other make that are shorter.......btw rear end is set up leaf link.........Thanks
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Need help drag shock rear a body [Re: 67mprfan] #1405701
03/21/13 05:57 AM
03/21/13 05:57 AM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Hello everyone
I found a shorter Rancho for mine........
Re: Need help drag shock rear a body [Re: 10.90 Racer] #1405702
03/21/13 09:54 AM
03/21/13 09:54 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have a shorter afco on mine.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Need help drag shock rear a body [Re: 10.90 Racer] #1405703
03/21/13 05:34 PM
03/21/13 05:34 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
do you have a part #
Re: Need help drag shock rear a body [Re: 1967dartgt] #1405704
03/21/13 05:35 PM
03/21/13 05:35 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Re: Need help drag shock rear a body [Re: 67mprfan] #1405705
03/21/13 06:06 PM
03/21/13 06:06 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i have a set of calvet one's i'm going to be selling soon. brad
Re: Need help drag shock rear a body [Re: a493demon] #1405706
03/21/13 07:12 PM
03/21/13 07:12 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
calvert does two different lengths for mopars, one for SS springs and one for caltracs.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Need help drag shock rear a body [Re: 67mprfan] #1405707
03/21/13 09:02 PM
03/21/13 09:02 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
3890m if I remember correctly.
Re: Need help drag shock rear a body [Re: 67mprfan] #1405708
03/22/13 12:12 AM
03/22/13 12:12 AM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
I will look tomorrow.....
Re: Need help drag shock rear a body [Re: 10.90 Racer] #1405709
03/22/13 02:51 AM
03/22/13 02:51 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
3890 is LONG, like 24 inches extended I think with 9 inches of travel. I've been doing alot of shock research recently and my car (@15.5 inch ride height between shock mounts) needs a 3860 from Afco (6 inches travel, closer to 20" fully extended. They also make a 3870 which is in between the two.
You need to take measurements of your suspension at ride height, with weight in the driver seat, as well as full droop/extension, and go from there.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Need help drag shock rear a body [Re: topfueldart] #1405710
03/22/13 09:45 PM
03/22/13 09:45 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
just measured from bolt -bolt quick reference and my is about 15.5
Re: Need help drag shock rear a body [Re: topfueldart] #1405711
03/22/13 10:08 PM
03/22/13 10:08 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Topfuel is correct mine are 3860 and my car measures 15 inch ride height.
Re: Need help drag shock rear a body [Re: 1967dartgt] #1405712
03/23/13 10:02 AM
03/23/13 10:02 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Afco #3860 on my '68 Valiant w/ladder bars and coilovers. Double adjustable, 125# springs. Car is a little over 3300# with driver.
If you like drag racing, support your local track.
Re: Need help drag shock rear a body [Re: CHAPPER] #1405713
03/24/13 08:38 PM
03/24/13 08:38 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
I've heard don't know how true but you can run a shock off of a 3/4 pick up truck with some sucess( staying on a budget)
